poorlittle
第61楼2008/07/25
The full-screen setting can be set as a default, used for new connections, and changed once a connection is active.
= The full-screen setting can be set as a default + The full-screen setting can be used for new connections +The full-screen setting can be changed once a connection is active.
connection is active = has been connected
所以我觉得 The full-screen setting can be changed once a connection is active 可能解作 “全屏模式可在连线後更改”, 不知操作上是不是这样。
youjian000
第62楼2008/07/25
设置好“全屏模式设置”,作为一个默认状态,新连接可(不用重新设置)直接使用该状态,连接一旦成功,“全屏模式设置”的内容立即生效。
chengjingbao
第63楼2008/07/25
这个翻译的正确性极高,可惜我没从实践中得到。有机会会试试的。
poorlittle
第65楼2008/07/27
Microsoft Internet Explorer (IE), Netscape Communicator (NC), Firefox are browsers, used in internet.
caj viewer, 维普全文浏览器, 超星浏览器 are viewers, used to view the documents.
Browser and viewer are two different tools in computer science, but both called 浏览器 in Chinese. It seems not appropriate and I consider that Chengjingbao’s translation of 阅读器 (i.e.超星阅读器) for viewer is better.
Anyway, the translation of viewer is not important here.
