adrian826
第11楼2009/12/08
如果做的话可以参考下面的实验条件:Technical details: Instrumentation: Modular Columns: PL HFIPgel guard plus two 300 x 7.7 mm, 9 µm, Solvent: 1,1,1,3,3,3 hexafluoro-2-propanol with NaTFAc Flow-rate: 0.8 mL/min (nominal) Temperature: 40°C Detector: refractive index
