阳线
第17楼2008/12/09
ASTM D 4715-98(R03) Standard Test Method for Coking Value of Tar and Pitch (Alcan)
中文名称:焦油和硬沥青焦化值的标准试验方法
ASTM D 5443-04 Standard Test Method for Paraffin, Naphthene, and Aromatic Hydrocarbon Type Analysis in Petroleum Distillates Through 200℃ by Multi-Dimensional Gas Chromatography
中文名称:200℃用多维气相色谱法分析石油馏份中石蜡、环烷和芳烃类型的标准试验方法
ASTM D 5443-04
ASTM D 5769-04 Standard Test Method for Determination of Benzene, Toluene, and Total Aromatics in Finished Gasolines by Gas Chromatography/Mass Spectrometry
中文名称:用气相色谱法测定汽油中苯和甲苯的标准试验方法
ASTM D 5769-04
ASTM D 5986-01 Standard Test Method for Determination of Oxygenates, Benzene, Toluene, C8–C12 Aromatics and Total Aromatics in Finished Gasoline by Gas Chromatography/Fourier Transform Infrared Spectroscopy
中文名称:用气相色谱傅里叶转换远红外线光谱对用完的汽油中C8-C12芳香族和总芳香族、甲苯、苯、氧化物测定的标准试验方法
ASTM D 5986-01
ASTM D 6074-99 Standard Guide for Characterizing Hydrocarbon Lubricant Base Oils
中文名称:烃类润滑基油特性的标准试验方法
ASTM D 6550-00 Standard Test Method for Determination of Olefin Content of Gasolines by Supercritical-Fluid Chromatography
中文名称:超临界液相色谱法测定汽油中烯烃含量的标准试验方法
阳线
第18楼2008/12/09
ASTM D 3117-03 Standard Test Method for Wax Appearance Point of Distillate Fuels
中文名称:馏出燃料蜡外观点的标准试验方法
ASTM D 3734-01 Standard Specification for High-Flash Aromatic Naphthas
中文名称:高闪点芳烃石脑油
ASTM D 3735-02 Standard Specification for VM&P Naphthas
中文名称:VM&P石脑油标准规格
ASTM D 3944-88(R00) Standard Test Method for Solidification Point of Petroleum Wax
中文名称:石蜡固化点的试验方法
阳线
第19楼2008/12/09
ASTM D 2171-01 Standard Test Method for Viscosity of Asphalts by Vacuum Capillary Viscometer
中文名称:真空毛细管粘度计测定沥青黏度的标准试验方法
ASTM D 2270-04 Standard Practice for Calculating Viscosity Index from Kinematic Viscosity at 40 and 100℃
中文名称:在40℃和100℃下从运动粘度换算成粘度指数的方法
ASTM D 2427-92(R01) Standard Test Method for Determination of C2 through C5 Hydrocarbons in Gasolines by Gas Chromatography
中文名称:气相色谱法测定汽油中C2至C5烃的试验方法
http://www.instrument.com.cn/bbs/download.asp?ID=89265
ASTM D 2569-97(R02) Standard Test Method for Distillation of Pitch
中文名称:硬沥青的蒸馏试验方法
