haiyonglu
第38楼2008/12/25
衬垫家具填充物阻燃测试样板要求
SAMPLE REQUIREMENT OF UPHOLSTERED FURNITURE FLAMMABILITY TESTS ON FOAM
序号 测试项目 测试标准 样板要求
1、UK Furniture and Furnishing (Fire Safety) Regulation 1988 英国家俬及家具防火安全条例1988
a) Ignitability test for polyurethane foam in slab or cushion form
块状PU海绵 Schedule 1 part 1
BS 5852 Part 2: Ignition Source 5 2pcs/块 450(L)X450(W)X75(H)mm海绵
2pcs/块 450(L)X300(W)X75(H)mm海绵
(共需4块海绵样板)
b) Ignitability test for polyurethane foam in crumb form 碎状PU海绵 Schedule 1 Part II
BS 5852 Part 2:1982 Ignition Source 2, 块状的要先通过Schedule 1 part 1 2pcs/块 450(L)X450(W)X75(H)mm海绵
(共需4块海绵样板)
2-3kg 碎海绵 with defined density
c) Ignitability test for latex rubber foam公仔绵 Schedule 1 part III
BS 5852 Part 2: Ignition Source 2 2pcs/块 450(L)X450(W)X75(H)mm海绵
d) Ignitability test for non-form filling materials singly 非海绵类 Schedule 2 part I
BS 5852 Part 2: Ignition Source 2 2-3kg/公斤with defined density
并提供最终产品中该填充料的填充密度
或提供以下4块海绵样板:
f) Ignitability test for composite filling materials singly
复合填充物 Schedule 2 part II
Schedule 1 Part I
BS 5852 part 2:1982 Ignition Source 5 If foam used
