才哥
第12楼2009/04/17
欧盟已经在修改REACH法规的附件17了,已经向WTO通报了。
修改后的版本,不但PFOS已经加入进去了,DECISION No 1348/2008/EC里提及的五种有害物质也加入加入进去了:DEGME、DEGBE、MDI、环己烷和硝酸铵。所以以后REACH法规的附件17就不再是52大类物质,而是58大类了。
至于DMF,这个决议2009/251/EC并没有提及说要加入到REACH中去,决议原文中有句话:Any restriction of DMF to be put in place under Regulation (EC) No 1907/2006 of the European Parliament and of the Council of 18 December 2006 concerning the Registration, Evaluation, Authorisation and Restriction of Chemicals (REACH), establishing a European Chemicals Agency, amending Directive 1999/45/EC and repealing Council Regulation (EEC) No 793/93 and Commission Regulation (EC) No 1488/94 as well as Council Directive 76/769/EEC and Commission Directives 91/155/EEC, 93/67/EEC, 93/105/EC and 2000/21/EC (6) would be impossible in the short term and would thus not suffice with regard to the urgency of the present risk management need.短期内,DMF应该是不会纳入REACH限制部分的。
