怪味陈皮
第16楼2009/05/15
我手头有几篇关于Al-Mg-Si合金的文献,瞄了几眼最佳的观察方向应该是〈001〉,不知道你的材料是不是相同。我觉得你可以试一下〈001〉和〈011〉。一篇文献中也总结了Al-Mg-Si合金中出现的析出相及转变过程,以后你可以按照这些结构来标定。文献也发上来,你看看对你有没有用。
The crystal structure of the phase in Al–Mg–Si alloys
Phase stability and structural features of matrix-embedded hardening precipitates in Al–Mg–Si alloys in the early stages of evolution
The structural relation between precipitates in Al–Mg–Si alloys, the Al-matrix and diamond silicon, with emphasis on the trigonal phase U1-MgAl2Si2
Crystal structure of the orthorhombic U2-Al4Mg4Si4 precipitate in the Al–Mg–Si alloy system and its relation to the β′ and β″ phases
The crystal structure of the β″ phase in Al–Mg–Si alloys
