何当奇
第11楼2009/06/15
明白了
poorlittle
第14楼2009/06/15
应是“一干人等”
A pending lawsuit is typically the basis for obtaining court-authorized discovery. Thus, a preliminary step to receiving court authorization is to file a valid complaint in court. If a federal claim is made, such complaints may be filed in federal court. Since the identity of the defendant is unknown, the defendant is typically listed as "John Doe" or "Jane Doe." Indeed, such cases are sometimes known as "John Doe" lawsuits. (In cases where there appears to be multiple defendants, they are listed as, for instance, "John Does 1-150.")
http://www.ibls.com/internet_law_news_portal_view.aspx?s=latestnews&id=2212
