第11楼2005/08/07
有可能,如果是解压缩正常得到了一个pdf文件,那么就是acrobat reader版本不够高,要6.0以上,或者用我上载的foxit软件试试。
第12楼2009/08/09
how are you going for SEM machine operating?i have leart SEM machine operating for one month,but I still often can not make image clear.Thanks for your question. so i find the great form.
