羽香
第57楼2009/08/16
Abstrast
Shuanghuanglian Oral Liquid,composed of Chlorhydric acid,radix scutellariae and Fructus Forsythiae. It is a species of Chinese traditional medicine. The preparation procedure and quality inspection of Shuanghuanglian Oral Liquid were stuidied in this acticle. The optimum extraction process of preparation was carried out with orthogonal test,and the craft of extraction by the single factor experiment, and I suruey the corrigent to choose suitable quantity. This result would be technology parameters for production of Shuanghuanglian Oral Liquid. It has been identified whether chlorhydric acid or baicalin not. Chlorhydric acid and baicalin of preparation exist or not in by Tlc-scanning Method. This detective index could be used to control the quality of Shuanghuanglian Oral Liquid preparation. To determine the content of chlorphenamine maleate and baicalin by HPLC and UV-2000 and regulate the minimum limit as the control of preparation quality, in order to insure clinical management rationality, safety and usefulness.
