影子
第12楼2009/09/23
The General Notices apply to all monographs and other texts of the European Pharmacopoeia.
这句话应译为:总体概述适用于欧洲药典中所有的专论以及其它的正文。
In the texts of the European Pharmacopoeia, the word ‘Pharmacopoeia’ without qualification means the European Pharmacopoeia. The official abbreviation Ph. Eur. may be used to indicate the European Pharmacopoeia.
这句话应译为:在欧洲药典正文中,“药典”一词如果没有限制,就是指欧洲药典。官方缩写Ph.Eur.用来表示欧洲药典。
Such references to monographs in the texts of the Pharmacopoeia are shown using the monograph title and reference number in italics.
这句话应译为:在药典正文中,对专论的参引以专论标题和斜体的参考号显示。
比如某品种项下对水分测定的参引:Water (2.5.12),这里的2.5.12并不表示页码,而是水分测定的专论号
影子
第13楼2009/09/23
The manufacturer may obtain assurance that a product is of Pharmacopoeia quality from data derived, for example, from validation studies of the manufacturing process and from in-process controls.
是否可译为:生产厂商可以从数据的来源上获得产品符合药典质量的保证,如来源于生产工艺验证研究的数据以及中控的数据。
Parametric release in circumstances deemed appropriate by the competent authority is thus not precluded by the need to comply with the Pharmacopoeia.
这句话的意思真的不太懂...?
poorlittle
第14楼2009/09/23
http://www.google.com.hk/search?hl=zh-TW&rlz=1G1GGLQ_ZH-TWHK330&q=parametric+release&btnG=%E6%90%9C%E5%B0%8B&meta=lr%3Dlang_zh-CN%7Clang_zh-TW&aq=f&oq=
Referring to the paper “浅析无菌药品的参数放行 : Parametric Release of Aseptic Drug Products” ( http://d.wanfangdata.com.cn/Periodical_zgyf200804004.aspx )
Parametric Release may be translated as 参数放行, which is probably a technical term in pharmacy, the professionals in this field would understand its implied menaing.
This sentence generally means 权威机构认为适当的参数放行亦需符合药典 (or 得权威机构认可的参数放行亦需符合药典)
Since both English and French are official languages for E.P., would this paragraph be translated from French?
