userwzy
第12楼2009/12/11
Use acetone as a marker, and calculate the EOF according to the migration time, column length and voltage.
If the EOF is very low, use 3 injection method. First, injection No.1 then flash with low pressure for several minutes, and then injection No. 2 and flash with some pressure and time, and add a volatege migrate several minutes, at last injection No. 3, then flush the column until the 3 peaks were shown. At last, according the distance difference between peak 1 and 2 and peak 2 and 3, migrate time and voltage calculte the EOF. it's an old paper, I think you can find it.
guocc007
第13楼2009/12/12
谢谢这位热心的版友,非常感谢!
