yanliangping
第24楼2010/03/05
下面是一个外国公司的同类产品价格及功能介绍
大家了解一下,这东西好像振荡96孔培养板,做分子生物学的挺好用
Thomas®
Thomas Multi-Tube Vortexer
Description
Additional Info
Hands-free vortexing of up to 50 tubes
Automatic timer
Electronic speed control
Thomas multi-tube vortexer can handle up to 50 tubes or three micro-assay plates. Cycle time is adjustable from 1200 to 2400 rpm with electronic speed control. Built-in timer is adjustable from one second to one minute or continuous operation. Various tube sizes can be mixed by simply changing the foam tube racks. Unit easily adjusts to different tube heights. Solid steel posts secure tube support for safe operation. Heavy-duty base features a scratch resistant enamel finish. Dimensions: 17.25” W x 9” D x 16” H. Shipping weight is 45 lbs.
Single Tube Holder
Please Enter Your Order Info
Filter by:
Thomas No. Mfr. No. Description List Price Ext. Price
8294C01 Multi-Tube Vortexer, 120V, 50/60 Hz $2,152.00/EA
1/EA
yanliangping
第25楼2010/03/06
另外一个牌子的,好像是国内代理做的
参考一下
Lab instruments > vortex mixers
NO.: EOFO-945008
Chinese Name: Talboys 基本型多管式旋涡混合器
English name: Standard Multi-Tube Vortexer
Model: 外形尺寸:24.1×38.4×40.6cm,包装重量:19.1kg
Brand:
Category: vortex mixers
CASNO:
Size Long: Width: Height:
Price: 24959.00 元
Offers Price:
Stock Status:
yanliangping
第26楼2010/03/06
下面是一个FDA推荐的测定三聚氰胺的文章,用的是 VWR的多管振荡器
FDA最新三聚氰胺测定方法
来源:安徽省兽药饲料监察所
Determination of Melamine and Cyanuric Acid Residues
in Infant Formula using $$lc-MS/MS
Sherri Turnipseed1, Christine Casey1, Cristina Nochetto2, David N. Heller2
1 Denver Laboratory, Office of Regulatory Affairs, Food and Drug Administration
2 Office of Research, Center for Veterinary Medicine, Food and Drug Administration
The Laboratory Information Bulletin is a communication from the Division of Field Science, Office of Regulatory Affairs, U.S. Food and Drug Administration for the rapid dissemination of laboratory methods (or scientific regulatory information) which appear to solve a problem or improve an existing problem. In many cases, however, the report may not represent completed analytical work. The reader must assure, by appropriate validation procedures, that the reported methods or techniques are reliable and accurate for use as a regulatory method. Reference to any commercial materials, equipment, or process does not, in any way, constitute approval, endorsement, or recommendation by the U.S. Food and Drug Administration.
Abstract
A liquid chromatography triple quadrupole tandem mass spectrometry ($$lc-MS/MS) method for residues of cyanuric acid (CYA) and melamine (MEL) developed by the Center for Veterinary Medicine (CVM) has been adapted for use with infant formula. This method consists of an initial extraction with 2.5% aqueous formic acid, followed by a series of filtration, centrifugation, and dilution steps. Both compounds are analyzed in the same chromatographic program using a zwitterionic HILIC $$lc column. Electrospray ionization is used in both the negative ion (CYA) and positive ion (MEL) modes. Two selected reaction monitoring (SRM) transitions are monitored for both compounds. The amount of compounds present is determined with a calibration curve consisting of sample extracts from infant formula fortified from 0.25 to 5 µg/g that have been taken through the extraction procedure. The range of recovery from fortified infant samples (n =38) was 70-114 % (RSDs 4.5- 22.7 %), and 72-110% (RSDs 5.7-24.9%) for cyanuric acid and melamine, respectively. The limits of quantification and confirmation are 0.25 µg/g for both analytes in dry infant formula.
Introduction
In 2007, pet food, animal feed, wheat gluten, and other protein-based food commodities were found to contain residues of melamine and a related compound, cyanuric acid. Widespread pet illness and death was subsequently attributed to the formation of melamine-cyanurate crystals in the kidneys of these animals. At that time, several laboratories developed methods for these compounds in pet food, raw protein sources, and other animal feeds. Because animals may eat food contaminated with melamine residues, analytical methods to determine melamine residues in fish and animal tissues were also developed. Recently, there has been a problem with contamination of infant formula with melamine and cyanuric acid in China. This is suspected of causing illness to many children in that country.
A procedure has been evaluated for the simultaneous determination and confirmation of melamine and cyanuric acid in powdered milk-based infant formula. Results are reported to support the continued evaluation and application of this method. Concentrations are measured in the range of 0.25 to 5 µg/g (µg/g). Extracts at higher concentrations may be diluted into this range. The limits of quantification and confirmation are 0.25 µg/g for both analytes.
Summary of Procedure
Powdered samples (2 g) are extracted with 14 mL 2.5 % aqueous formic acid in a 50 mL polypropylene centrifuge tube. Extracts are centrifuged at 3750 g and then 1.4 mL of supernatant is transferred to a polypropylene Eppendorf tube and centrifuged at 16100 g (benchtop micro centrifuge). The extracts are filtered through PVDF syringe filters (0.2 micron pore) followed by dilution with acetonitrile and a second centrifugation at 16100 g. The extracts are analyzed by $$lc-MS/MS. A zwitterionic HILIC column is used to separate melamine from cyanuric acid. Melamine is detected in positive ion mode and cyanuric acid is detected in negative ion mode. Analyte concentrations are ca$$lculated using external standard calibration with a standard curve prepared in a pre-fortified control matrix which has been carried through the extraction procedure.
Standards and Reagents
Melamine (MEL). CAS #: 108-78-1. Sigma Chemical Company.
Cyanuric acid (CYA). CAS #: 504-19-8. Fisher Chemical Company or TCI America.
Acetonitrile (ACN.) $$lc grade. Burdick & Jackson high purity or equivalent.
Formic acid. Reagent grade ≥ 95%. Sigma-Aldrich or Fisher Chemical Company.
Water. $$lc grade, or purified by Millipore Milli-Q system to > 18 M-ohm resistivity, or equivalent.
Ammonium Formate. Sigma-Aldrich or Fisher. Purity > 97%.
Solutions:
0.1% Formic acid in water. Transfer 1 mL formic acid to 1 L graduated flask. Dilute to volume with $$lc water.
Mobile Phase A. 0.1% Formic acid in Acetonitrile (5:95 v/v). Combine 50 mL of 0.1% formic acid in water with 950 mL ACN in a 1 L solvent bottle.
Mobile Phase B. 20 mM Ammonium Formate in Acetonitrile (50:50 v/v). Combine 500 mL of 20 mM ammonium formate and 500 mL of acetonitrile in a 1 L solvent bottle.
2.5% Formic acid in water. Transfer 25 mL formic acid to 1 L volumetric flask. Dilute to volume with $$lc grade water.
20 mM Ammonium formate. Weigh 0.63 g of ammonium formate and dissolve in 0.5 L $$lc grade water.
Equipment
Liquid chromatograph. Binary $$lc pump is recommended for accurate mixing at low flow rate and rapid response to mobile phase gradient. (Waters, Agilent, Thermo Surveyor, or equivalent)
Liquid chromatography column. ZIC-HILIC, 2.1 x 150mm, 5µm, 200 Å, (Available in US from Nest Group #Q2712-152) (Merck Sequant)
Mass Spectrometer. Triple quadrupole capable of meeting system suitability. System used in the validation of infant formula was a Thermo (San Jose, CA) TSQ Quantum triple quadrupole mass spectrometer coupled to a Thermo Surveyor $$lc-MS pump and autosampler.
Centrifuge. Capable of 4000 RPM with 50 mL tubes.
Microcentrifuge. Capable of 13,000 RPM with 1.5 or 2 mL tubes. (Eppendorf or equivalent)
Mixers and shakers. Single and multi tube vortex mixers (VWR), platform shaker.
Utrasonic bath. Including timer and heater
Centrifuge tubes. 50mL disposable polypropylene with caps, with graduations from 5 to 50 mL and 1.5 mL microcentrifuge tubes.
Syringe Filters. Polyvinylidene fluoride (PVDF), 13mm, 0.22um (Whatman Puradisc™)
Syringes. Three mL polypropylene.
yanliangping
第27楼2010/03/06
下面是个kytose公司的多管振荡器的特点介绍
好像对做生化的,颗粒再悬浮,细胞悬浮挺有用
Features:
The intelligent vortex shaker has
programmable speed up to 3200 RPM
vigorous mixing of capped vessels
Accommodates from 18 tubes (30 mm dia) to
72 tubes (11 mm or 13 mm dia)
Continuous and intermittent modes of
operation
Programmable automatic switching between
continuous and intermittent modes (Patent
Pending)
Visual and audible alert on test completion
Ideal for biochemical assays, resuspending
pellets, vortexing cell suspensions and liquidliquid
extractions
yanliangping
第28楼2010/03/06
最详细的应用范围,介绍给大家
The Multitube Vortexer is designed for mechanical and chemical cell lysis, mixing suspensions, and general sample agitation. This vortex mixer gives a distinctly different motion than shaking a sample. With vortexing, greater shearing forces are placed on materials in the bottom of a tube, thus promoting either disruption or solubility. The multi-tube vortex mixer is a tool to provide that extra degree of mixing, however it accommodates full racks of tubes or microwell plates as opposed to singe tubes. Consequently, this unit is useful for higher throughput mixing of samples.
The multi tube vortexer can be used for resuspending bacterial pellets, mixing reagents for alkaline lysis plasmid preps, mixing of components for bead-based assays, mixing of aqueous and organic solutions for extractions, mixing of solid phase supports and reactants, and any other process which requires a vortexing step. This mixer is sturdy yet quiet in operation.
The multi-tube vortexer is available as analog and digital modules in both 120 and 230V configurations.
