johne0212
第15楼2010/05/16
Yes, Just one bottle Chromatography grade. One Agilent engineer and i both check it again, we are sure it is not the solvent list on the label. However we go ahead purchasing Merck, sometime we used LC/MS grade to avoid some noise trouble from the solvent.
