gdon9540
第11楼2010/06/09
谢谢大侠,请问一下您所说的检测器调零怎么操作呢,还有PRINT LEVEL怎么调呀?
我的数据处理器(DATA PROCESSOR: R-C8A)的参数设置如下,除了那个ATTEN之外, 您看看哪里需要改动:
1. designate the minimum peak width: 10
2. peak detection sensitivity: slope = 300,
3. baseline drift's threshold: drift = 0
4. time to change the width and slope values: T.DBL =1000
5. time to stop the analysis: STOP TM = 25
6. plotter sensitivity: ATTEN =4
7. paper feed speed: SPEED = 10
8. METHOD = 1, NORMALIZATION
9. CURVE = 00, LINEAR FIT
10. the number of calibration: CAL.LEVL = 1
11. minimum peak area: MIN. AREA = 1000
12. method of peak allowable width: WIN. BAND = 0
13. peak allowable width: WINDOW = 5
14. sample's absolute amount: SPL. WT = 100 (这里一个问题,这个进样量的单位是什么?)
15. internal standard amount: IS. WT = 1
16. sample dilution factor: DILFACT = 1
