省部重点实验室
第13楼2010/11/14
第二部分 SCI论文写作
一、写作框架和各部分要求
Title: Be short, accurate, and unambiguous; Give your paper a distinct personality; Begin with the subject of the study.
Introduction: What is known; What is unknown; Why we did this study?
Methods: Participants, subjects; Measurements; Outcomes and explanatory variables; Statistical methods.
Results: Sample characteristics; Univariate analyses; Bivariate analyses; Multivariate analyses.
Tables and figures: No more than six tables or figures; Use Table 1 for sample characteristics (no P values); Put most important findings in a figure.
Discussion: State what you found; Outline the strengths and limitations of the study; Discuss the relevance to current literature; Outline your implications with a clear "So what?" and "Where now?"
References: All citations must be accurate; Include only the most important, most rigorous, and most recent literature; Quote only published journal articles or books; Never quote "second hand"; Cite only 20-35 references.
Formatting: Include the title, author, page numbers, etc. in headers and footers; Start each section on a new page; Format titles and subtitles consistently; Comply with "Instructions to authors".
省部重点实验室
第14楼2010/11/15
二、英文写作的语言技巧
1. Introduction:
A. 如何指出当前研究的不足并有目的地引导出自己研究的重要性?在叙述前人成果之后,用However来引导不足,提出一种新方法或新方向。如:However, little information(little attention/little work/little data/little research……)(or few studies/few investigations/few researchers/few attempts……)(or no/none of these studies……)has(have)been done on(focused on/attempted to/conducted/investigated/studied(with respect to))。如:Previous research (studies, records) has (have) failed to consider/ ignored/ misinterpreted/ neglected to/overestimated, underestimated/misleaded. thus, these previous results are inconclisive, misleading, unsatisfactory, questionable, controversial. Uncertainties (discrepancies) still exist……研究方法和方向与前人一样时,可通过以下方式强调自己工作:However, data is still scarce(rare, less accurate),We need to(aim to, have to) provide more documents(data, records, studies, increase the dataset). Further studies are still necessary(essential)……
强调自己研究的重要性,一般还要在However之前介绍与自己研究问题相反或相关的问题。比如:(1)时间问题;(2)研究手段问题;(3)研究区域问题;(4)不确定性;(5)提出自己的假设来验证。如果你研究的问题在时间上比较新,你可大量提及时间较老问题的研究及重要性,然后(However)表明“对时间尺度比较新的问题研究不足”;如果你的是一种新的研究手段或研究方向,你可提出当前流行的方法及其物质性质,然后(However)说对你所研究的方向方法研究甚少;如果研究涉及区域问题,就先总结相邻区域或其它区域的研究,然后 (However)强调这一区域的研究不足;虽然前人对某一问题研究很多,但目前有两种或更多种观点,这种uncertainties或 ambiguities值得进一步澄清;如果自己的研究是全是新的,没有前人的工作可对比,你就可以自信地说“根据假设提出的过程,存在这种可能的结果,本文就是要证实这种结果”等等。We aim to test the feasibility (reliability) of the……It is hoped that the question will be resolved (fall away) with our proposed method (approach).
B. 提出自己的观点:We aim to//This paper reports on//This paper provides results//This paper extends the method//This paper focus on……The purpose of this paper is to……Furthermore, Moreover, In addition, we will also discuss……
C. 圈定自己的研究范围:introduction的另一个作用就是告诉读者(包括reviewer),你文章的主要研究内容。如果处理不好,reviewer会提出严厉的建议,比如你没有考虑某种可能性,某种研究手段等。为减少这种争论,在前言的结尾就必须明确提出本文研究的范围:(1) 时间尺度;(2) 研究区域等。如涉及较长的时序,你可明确提出本文只关心某一特定时间范围的问题,We preliminarily focus on the older (younger)……如有两种时间尺度 (long-term and short term),你可说两者都重要,但是本文只涉及其中一种。研究区域的问题,和时间问题一样,也需明确提出你只关心某一特定区域!
D. 最后的圆场:在前言的最后,还可以总结性地提出“这一研究对其它研究有什么帮助”;或者说further studies on……will be summarized in our next study (or elsewhere)。总之,其目的就是让读者把思路集中到你要讨论的问题上来。尽量减少不必要的争论(arguments)。
2. Discussion:
A. 怎样提出观点:在提出自己的观点时,采取什么样的策略很重要,不合适的句子通常会遭到reviewer置疑。(1)如果观点不是这篇文章最新提出的,通常要用We confirm that……(2)对于自己很自信的观点,可用We believe that……(3)通常,由数据推断出一定的结论,用Results indicate, infer, suggest, imply that……(4) 在极其特别时才可用We put forward(discover, observe)……"for the first time"来强调自己的创新……(5) 如果自己对所提出的观点不完全肯定,可用We tentatively put forward (interrprete this to…)Or The results may be due to (caused by) attributed to resulted from……Or This is probably a consequence of……It seems that……can account for (interpret) this……Or It is posible that it stem from……要注意这些结构要合理搭配。如果通篇是类型1)和5),那这篇文章的意义就大打折扣。如果全是2),肯定会遭到置疑。所以要仔细分析自己成果的创新性以及可信度。
B. 连接词与逻辑:写英文论文最常见的毛病是文章的逻辑不清楚,解决方法如下。
(1)注意句子上下连贯,不能让句子独立。常见的连接词有,However, also, in addition, consequently, afterwards, moreover, Furthermore, further, although, unlike, in contrast, Similarly, Unfortunately, alternatively, parallel results, In order to, despite, For example, Compared with, other results, thus, therefore……用好连接词能使文章层次清楚,意思明确。比如,叙述有时间顺序的事件或文献,最早的文献可用AA advocated it for the first time.接下来可用Then BB further demonstrated that. 再接下来,可用Afterwards, CC……如果还有,可用More recent studies by DD……如果叙述两种观点,要把它们截然分开AA put forward that……In contrast, BB believe or Unlike AA, BB suggest or On the contrary (表明前面观点错误),如果只表明两种观点对立,用in contrast BB……如果两种观点相近,可用AA suggest……Similarily, alternatively, BB……Or Also, BB or BB allso does……表示因果或者前后关系可用Consequently, therefore, as a result……表明递进关系可用furthermore, further, moreover, in addition……写完一段英文,最好首先检查是否较好地应用了这些连接词。
(2) 注意段落布局的整体逻辑:经常我们要叙述一个问题的几个方面。这种情况下,一定要注意逻辑结构。第一段要明确告诉读者你要讨论几个部份……Therefore, there are three aspects of this problem have to be addressed. The first question involves……The second problem relates to……The third aspect deals with……清晰地把观点逐层叙述。也可以直接用First, Second, Third, Finally……当然,Furthermore, in addition等可以用来补充说明。
(3) 讨论部份的整体结构:小标题是把问题分为几个片段的好方法。通常第一个片段指出文章最重要的数据或结果;补充说明部份放在最后一个片段。一定要明白,文章的读者分为多个档次;除了本专业的专业人士读懂以外,一定要想办法能让更多的外专业人读懂。所以可以把讨论部份分为两部份,一部份提出观点,另一部份详细介绍过程以及论述的依据。这样专业外的人士可以了解文章的主要观点,比较专业的讨论他可以把它当成黑箱子,而这一部份本专业人士可以进一步研究。
C. 讨论部分包括什么内容?(1)主要数据及其特征的总结;(2)主要结论及与前人观点的对比;(3) 本文的不足。对第三点,一般作者看来不可取,但事实上给出文章的不足恰恰是保护自己文章的重要手段。如果刻意隐藏文章的漏洞,觉得别人看不出来,是非常不明智的。所谓不足,包括以下内容:(1)研究的问题有点片面,讨论时一定要说,It should be noted that this study has examined only……We concentrate (focus) on only……We have to point out that we do not……Some limitations of this study are……(2)结论有些不足,The results do not imply……The results can not be used to determine(or be taken as evidence of)……Unfortunately, we can not determine this from this data……Our results are lack of……但指出这些不足之后,一定要马上再次加强本文的重要性以及可能采取的手段来解决这些不足,为别人或者自己的下一步研究打下伏笔。Not withstanding its limitation, this study does suggest……However, these problems could be solved if we consider……Despite its preliminary character, this study can clearly indicate……用中文来说这是左右逢源,把审稿人想到的问题提前给一个交代,同时表明你已经在思考这些问题,但是由于文章长度,试验进度或者试验手段的制约,暂时不能回答这些问题。但通过你的一些建议,这些问题在将来的研究中有可能实现。
3. Others:
A. 为使文章清楚,第一次提出概念时,最好以括弧给出较详细解释。如文章用了很多Abbreviation可用两种方法解决:(1) 在文章最后加上个Appendix,把所有Abbreviation列表;(2)在不同页面上不时地给出Abbreviation的含义,用来提醒读者。
B. 绝对不能全面否定前人的成果,即使在你看来前人的结论完全不对。这是对前人工作最起码的尊重,英文叫做给别人的工作credits.所以文章不要出现非常 negative的评价,比如Their results are wrong, very questionable, have no commensence, etc.遇到这类情况,可以婉转地提出:Their studies may be more reasonable if they had……considered this situation.Their results could be better convinced if they……Or Their conclusion may remain some uncertanties.
省部重点实验室
第16楼2010/11/16
三、撰写外刊论文的体会
有人归纳了外刊论文撰写的五个基本要求,即5C:正确(correctness)、清楚(clarity)、简洁(concision)、完整(completion)和一致性(consistency) 。只有满足这5点,才算是一篇合格的外刊文章。
1. Introduction:
Introduction 是外刊文章最难写的部分之一(另外就是Discussion)。中文文章的缺陷就在于Introduction没有内涵,过于简单,没有真正体现论文的研究起初和创新要素。外刊论文对于Introduction的要求是非常高的,一个好的Introduction相当于文章成功了一半。所以大家应该在 Introduction的撰写上下功夫。要写好Introduction,最重要的是要保持鲜明的层次感和极强的逻辑性,这两点是紧密结的,即在符合逻辑性的基础上建立层层递进的关系。
A. 阐述自己研究领域的基本内容。要尽量简洁明了,不罗嗦;须知看文章者都是该领域的专家,所以一些显而易见的知识要用概括性的而不是叙述性的语言来描述。
B. 文献总结回顾。是Introduction的重头戏之一,要特别着重笔墨来描写。一方面要把该领域内过去和现在的状况全面概括总结出来,不能有丝毫的遗漏,特别是最新的进展和过去经典文献的引用(这是两个最容易出问题的地方,要极力避免;一旦审稿人指出这两个毛病,很可能意味着表明你做的不够深入或全面,负面作用非常明显)。另一方面,文献引用和数据提供一定要准确,切记避免片面摘录部分结果而不反映文献的总体结果;引用的数据也要正确,特别是间接引用的数据(即不是从原文献中查到,而是从别人文献中发现的另一篇文献的数据);数据出错会导致文章的印象特差!此外,引用文献时注意防止造成抄袭的印象,即不要原文抄录,要用自己的话进行总结描述。如果审稿人正好是文献的引用者的话,原文照抄的结果一定会很糟糕。
C. 分析过去研究的局限性并阐明自己研究的创新点。这是整个Introduction的高潮,因而要慎之又慎。阐述局限性时,需要客观公正评价别人的工作,不要把抬高自己研究的价值建立在贬低别人的工作之上(这是中文文章易犯的毛病),外刊论文写作万万不可如此,一定要遵循实事求是的原则来分析。在阐述自己的创新点时,要紧紧围绕过去研究的缺陷性来描述,完整而清晰地描述自己的解决思路。需要注意文章的摊子不要铺的太大,要抓住一点进行深入的阐述。只要能够很好的解决一个问题,就是篇好文章;创新性描述的越多越大,越容易被审稿人抓住把柄。中文文章的特点是创新性要多要大,而英文文章的特点恰恰相反,深入系统的解决一到两个问题就算相当不错。
D. 总结性描述论文的研究内容,可以分为一二三四等几个方面来描述,为Introduction做最后的收尾工作。至此,Introduction的写作算是大功告成。但是写完之后,还是要慎之又慎的仔细修改,琢磨每一个句子是否表达得恰当准确,这对 Introduction的修改完善至关重要。
2. Methods:
Methods 部分描述论文实验过程,这一过程的写作相对较为简单,但是需注意的问题不少,重要的在于完整和科学。完整就是实验当中的每一个环节都要注意到,不要顾此失彼,遗漏一些重要内容。Methods部分可按实验对象、实验设备、实验材料、实验记录、实验分析方法等来组织行文。只要能在以下4个方面做到完整和科学的描述,相信写好Methods不是主要问题。
A. 实验对象一般是人、动物或一些组织等,它们的基本信息要描述明确;此外要注意国外刊物大多对牵扯到人或动物的实验都有一些特定要求,有些是不允许在人或动物身上进行的实验操作,这需要认真阅读投稿刊物中关于实验的详细规定;如果违反这一规定,可能会不接受评审或发表。
B. 实验设备,要对仪器型号、生产厂家、实验过程中的用途等作详细说明;实验设备之间的连接要科学正确,不要给人混乱或操作错误的感觉。设备使用时一些必要的步骤不可或缺,尤其是可能对实验结果造成特定影响的操作更要详细说明。这样做的好处是为了在Discussion中能够进行对应的分析。比如,一些设备在使用前要校正(calibration),有的要求每阶段实验之后都要重新校正,以保证结果的正确性;一定要详细说明你的操作步骤或校正过程,便于评审人分析你的结果。
C. 实验材料,不同学科有不同要求。总体上来说要注意说明材料选择的必要性,也就是对为什么要选择这种材料,最好有一定的说明。如果这点描述不清,可能会导致整个实验过程不成立。
D. 实验过程,就是清楚描述实验的整个操作流程,一般要附以实验流程图进行说明。流程图的画法很多,有文字式的,有文字和示意图结合的,不同实验有不同做法。一般来说,可能后者多一些(实验性学科尤其如此),因为这样能使评审人对实验过程一目了然。如果示意图画得漂亮,还可以增加一些印象分。描述时要有鲜明的层次感,对每个步骤之间的顺序和关联要描述清楚,不要造成实验过程混乱不堪的印象,因为评审人最终判断你的实验是否合理,是从这个过程描述得来的。
3. Results:
有人把Results和Discussion放在一起写,但是大多数论文都是分开的。这两种做法取决于文章的类型。如果你的结果在分析的同时进行讨论更加合适,并不适合单独拿出来分析(或者是那样做很困难,导致Discussion成为鸡肋时),合在一起是合适的;反之就应该分开写。
A. Results的要求是翔实准确。准确是结果必须是真实的,不能伪造和篡改。翔实是提供最全面的分析结果,把一切从实验中得到的结果都提供给读者,不要故意隐瞒或遗漏某些重要结果。从某种意义上来说,结果不够翔实并不导致论文直接被拒,但结果的真实性被怀疑文章就肯定被拒。
B. 结果提供一般是表和图。不同杂志对图表要求不完全一致,应根据杂志要求分别对待。表格能清晰展示论文获得的第一手结果,便于后人在研究时进行引用和对比。图示能将数据的变化趋势灵活的表现出来,更直接和富于感染力。图表结合,能取长补短,使结果展现更丰富。目前,大家越来越喜欢提供各种各样的图,但杂志却要尽量限制图的个数;因为会增加排版的困难,版面费和出版社的支出也就会增加。因此,建议大家在提供图时,尽量用最少的图提供最多的信息,最多不超过8 个。图片太多显得罗索和累赘,主编不会欣赏;必要时可用表格替代一些图。图片格式要求每个杂志不同,用tif格式较多,不推荐用bmp(jpg更不能用)。有人说用矢量图清楚些,其实和tif没什么区别,只要足够清晰就行。黑白图片可免费,彩色图片绝对要收费,而且价格不菲。
C. Results和Discussion分开写时,Results部分尽量不要涉及对结果的评论,最多是总结陈述结果就可以了。否则造成这两部分的内容重叠,显得累赘,从而对Discussion不利。结果的描述也要注意层次安排,要按照条理性要求分别描述,显得逻辑性较强。不要乱七八糟,降低论文的可读性。
D. Results中大多要提供统计结果。方差分析的结果形式要根据刊物的格式给出,有的要求对分析值、自由度和概率都要详细的给出,有的只要分析值和概率就可以了。概率可以用p=0.02或者p<0.03等形式给出,自由度的表达也有特殊要求。这些细节问题虽然关系不大,但是注意格式统一,不要乱七八糟各自为战。统计分析结果过多时,可用表格给出,具体可参照SPSS软件分析之后的结果。如果论文结果部分通篇都是统计分析的数据,会显得凌乱不堪,表格可以避免这种情况。
4. Discussion:
Introduction和Discussion是最难写的两部分。 Discussion之所以难写,是因为这里面最能够显示一个作者研究问题的深度和广度。深度就是论文对于提出问题的研究到了一个什么样的程度,广度指是否能够从多个角度来分析解释实验结果。要写好Discussion,大概可以分为下面两个步骤:
A. 选择要深入讨论的问题。Results中有的结果是重要的,有的则可一笔带过。选择合适的结果在Discussion部分进行深入讨论,是写好该部分首先要面临的问题。一般来说,可根据如下原则来判断:如果你的结果体现了实验的独特性,是其他研究中没有得到的,那这个结果就是要重点讨论的问题;有些结果和前人的研究一致,并没有显著性差异,就应该一笔带过而无需深入讨论。Discussion的一个重要作用就是要突出自己研究的创新性,并体现出显著区别于他人的特点,区别大和小是另外一个问题,重要的是要有区别、区别就是创新。
B. 对选中的问题按一定层次从多个角度进行讨论,说理要有根据、问题要讲清楚、讲透彻。选择的问题有时不只一个(多数情况是2个以上),因此要按一定层次描述清楚。一般来说,把最重要的放在中间,次之的放开头和末尾。放在中间能将评审人的情绪带至高潮,前面是铺垫,后面是总结。这样的顺序似乎更合适。问题无论大小,是否重要,都要从多个角度展开深入讨论:(1)首先要有类似结果的对比,说明自己结论的独特性;(2)其次要系统阐述为什么会有这样的结果,方法有多种(从实验设计角度,从理论原理角度,从分析方法角度,或借鉴别人分析方法等等)。重要的是将这个问题深入阐述清楚,不能让人有意犹未尽之感(要做到这点的确很困难,因为评审人总会提出新的问题,我们只可能尽量做到这一点罢了)。
C. Discussion部分还要注意保持和Results的一致性!就是结果和讨论要一一对应。千万不要出现按讨论的内容可以推出与实验相反的结论这种情形,那证明你的讨论思路是彻底的失败或你的实验压根儿就是失败的。所以Discussion的文字描述和语言表达的精确性尤为重要。由于中英文表达的不同,在投稿之前要尽量避免出现表达上的误解,如果论文因此被拒是很冤枉的。
5. Acknowledge & References:
Acknowledge 主要分为两个:第一是表明研究的基金来源,中国一般都是Nature Science Foundation of China(NSFC,国家自然科学基金),美国大多是National Institute of Health(NIH,美国国家卫生研究院)。写基金时一般要标注清楚基金号码(Grant Number),只有这样才算是该项基金的研究成果,也可以算做实验室的研究成果。须知没有任何一项研究成果是在没有资金资助的情况下完成的,所以这一点非常必要。第二是对参与人员(没有列在作者中的研究人员)和单位表示感谢,如果通过一审和最终接受发表,还要添上对editor和anonymous reviewers的感谢,这是基本礼貌。
References重要在于格式。不同杂志对参考文献格式要求不一样,具体下来有所区别的可以分为:作者的写法,有的是简写在前,有的简写在后,有的简写有点,有的简写没有点;文章的名字,有的要加上引号,有的没有引号;期刊的写法,有的要简写,有的要全称,有的要斜体,有的则不需要;年和期卷号的顺序,有的是年在前,有的是年在后;期刊论文、书、学位论文、会议论文,四种引用的格式各不相同;文献的排列顺序,有的是按照字母的顺序,有的则是按照在论文中出现的顺序用阿拉伯数字排序。基本上就是这些问题,看来很是琐碎,但是如果你的参考文献排列的乱七八糟,那就会使得评审人对你论文的印象很差,认为你没有认知组织和撰写论文,造成一定的负面影响。所以,事情虽小,影响却大,还是要认真组织为好。
此外,论文在撰写时要自始至终都用英语写,千万不要先写中文再译成英文。这样写出来的文章肯定是中不中,英不英,而且极大浪费精力。宁可一开始写得语法差一些,慢慢修改都比这种写法好。如果有同专业英语比较好的人帮助的话,这样写还会更省事。写作时行文时态要注意,中文没有时态问题,英文有,而且要求还相当严格。一般来说,大多数情况下是过去时态,在Introduction文献回顾,Methods整个部分,Results结果总结,Discussion中的大部分,都用过去时态陈述。其他情况下可以用一般时态来描述。时态之间的界限是比较严格的,最好是仔细的通读国外的论文,好好分析一下,或者让有经验的人帮你把把关,这样比较好一些。
省部重点实验室
第17楼2010/11/17
四、Writing Skills in English for Research Paper
写 paper注意九个环节:Preparation, Structure, Title, Abstracts, Introduction, Conclusion, Body of Paper, Recision, Acknowledgement。Preparation就是收集资料,找出灵感和方向,主要依靠的是journal in library。Structure是重点,paper的structure应该是两个triangle组成的:上面一个倒三角,下面一个正三角,意思就是选题要宽(wide),研究方向要窄,然后最后的conclusion又发散开来。在paper的body前后都必须有declarative statement,用最少的字句表达出自己的观点,吸引读者。
Title必须清晰简短(clear,short),表达出自己唯一的topic以提升读者的兴趣(promote the interest of reader),然而title中切记不能出现abbreviation和自己的result。
Abstracts 是paper的一个缩写(miniature of whole paper),一定要简明扼要(less than 200 words,one paragraph),按照paper的顺序介绍主要研究对象(subject)、实验设计(design)、实验步骤(procedures)以及最后结果(results),这种介绍必须让非专业的人员 (non-specialist) 能够看懂。
Introduction同样要保证简短,顺序是一般背景介绍、别人工作成果、自己的研究目的及工作简介,其中介绍别人工作时只需介绍和自己最相关的方面 (very relevant),而对自己的工作介绍不用说明细节,因为这个要放到body中去。不要忘记在介绍自己工作之前要有一个declarative statement。
Body部分可以分为methods、result和discussion三个部分:①Methods,详尽的介绍自己的实验方案以便于他人能够重复自己的实验过程,对于通用的实验方案可以简略,重点要放到自己的独创方案上面(own procedures),按照实验的先后顺序介绍,为了文章的阅读方便,不要使用过多层次的subheadings,比如 subsubsubsection等等。②Result,使用text、table、figure等手段表达出来,其中table不要使用过多,而 figure必须保证图线清楚、注解明确,必要的时候还要对于自己的result中的一些结论进行解释说明。③Discussion,这个部分是为了以后的study,在其中提出自己的problem或者是hypothesis,和别人的成果进行比较,暗示自己的主要收获,为后面的conclusion做准备。
Conclusion中不要包含body以外的information,保持brief、neat和concise,一定要舍得结束自己的paper;如果自己的paper只是project的一部分,稍做说明。Revison是在写完之后回头看看是否有逻辑上的错误,是否考虑到了读者兴趣,自己的 declarative statement是否令人满意,Brevity is the soul of literary construction。Acknowledgement,不要忘记,这个反应了一个人的个人品质。
五、撰写论文初稿(writing the first draft):
(1)材料和方法(methods and materials):做了什么和怎样做?材料和方法是文章开始写作的最理想部分,这部分的内容作者最了解。写作要求:用过去时,尽可能按实验的先后顺序描述。
(2)结果(results):发生了什么?基本写作要求:可用图、表或文字表达,三者间尽量减少重复。在正文部分叙述主要结果和意义,用图或表给出较详细的数据,用过去时。
(3) 讨论(discussion):所得结果是否为“前言”提出的关键问题的答案?结果是如何支持答案的、如何证实假说的?基本写作要求:集中讨论与本结果有关的问题,突出本研究的创新及重要性,;与相关研究结果进行比较分析;给出结果所支持的结论;指出前景、不足和改进。用现在时叙述已知或被证明的事实,用过去时描述本研究结果。
(4)文献(references):与本研究方法、结果、讨论有关的其它研究有哪些?准确完整规范著录。
(5)前言(introduction)本研究的背景和目的是什么?试图回答的关键问题是什么?基本写作要求:本研究之目的和重要性;简要复习文献。
致谢(acknowledgment):除了作者,谁协助完成了本研究、分析结果并撰写论文?谁提供了基金和物质帮助?写作要求:仅列出对本工作提供特殊的实质性贡献者姓名;须得到被致谢者同意。
(7) 摘要(abstract):论文告诉我们什么(通常<250字)?摘要是论文要点的浓缩,应在文章各主要部分完成后再写,这样有利于文章要点的提炼。优秀的摘要能有效抓住读者兴趣。写作要求:用含有必要词汇的短的简单句,以使摘要清楚而简洁?避免使用缩写词和晦涩难懂的词句;用小标题叙述研究论文的各部分;用过去时(但问题的陈述和结论可用现在时);强调研究的创新和重要方面。
文题(title):本文关于什么?最佳文题的标准是用最少的必要术语准确描述论文的内容。写作要求:准确(accuracy)、简洁(brevity)、有效(effectiveness)和吸引人。
(9)作者(author list):谁参与了本研究的设计、工作及论文的撰写?
(10) 准备论文最后一稿(preparing the final manuscript):论文初稿完成以后,必须对内容及格式进行反复推敲和修改,达到“投稿须知”的一切要求。绝大多数有经验的编辑都认为:不认真准备的稿件绝不是高水平科学研究成果的良好载体(A poorly prepared manuscript. is,almost without fail,the carrier vehicle of poor science. Day AR.)。如果希望论文发表,在准备投稿时必须做到打字整洁、无错、符合期刊格式、含有期刊要求的所有材料。该过程一般分三步:再次阅读拟投期刊的“投稿须知”;用“投稿须知”中提供的“稿件对照检查表”(manuscript. checklist, author's checklist)与自己论文一一核对;根据期刊要求打印输出,完成最后一稿。
省部重点实验室
第19楼2010/11/18
六、英语学术论文写作的几个细节
A. 时态:当提到本文、此图、此表等说明了、表达了什么时要用一般现在时,而不用一般过去时。This paper describes ……The focus of this paper is ……Figure 1 shows ……Most of the common condensation polymers are listed in Table 1-1.
B. 数:在学术论文里,有时很难顾及数的逻辑。但一般不将逻辑上的问题视为语法错误。只须注意在一个句子中的数和谓语动词的统一即可。单、复数的选用有一些非定性、但可供参考的趋向:
◆◆ 当含意上强调复数时建议用复数。The catalyst concentrations for the different reactions are different.Our research focuses on the syntheses and characterizations of a series of polycarbonates with different chemical structures.The physical and chemical properties of this compound have been studied.The chain lengths of the oligomers with different molecular weights are different.
◆◆当含意上不强调复数时可用单数或复数。Our research focuses on the synthesis of polycarbonates.The property of the compounds in group 1 is different from the property of the compounds in group 2.The chain length of the oligomers increases with increasing reaction time.
◆◆在标题、小标题中或描述一类事物、现象等,提到具体物质时常用复数。【Polyesters】 Polymers are macromolecules built up by large numbers of small molecules. The small molecules which combine with each other to form. polymer molecules are termed monomers.在标题、小标题或描述一类事物、现象等,提到抽象概念时可用单数、也可用复数。【Step Copolymerization】Newer Types of Step Polymerizations. This chapter will consider the characteristics of step polymerization in detail.
◆◆学术论文、有关学术的科普文章中的名词的可数或不可数特性的划分区别于非学术文章《非学术文章中的可数或不可数特性可从字典查到》。以下是在学术文章中通常视为可数名词的单词:《但在一般字典中它们或它们做某种含义解时可能被划归不可数名词》。
application development consideration
composition concentration distribution
structure length weight
◆◆ 当同时提及几个图、表、方程式时要用复数(分别单个地提及则不用):The reaction rate constant can be calculated from Equations 2 and 3. The reaction rate constant can be calculated from Equation 2 and Equation 3. Figs. 4 and 5 show ……
C. 冠词:
◆◆单数名词前一般要加冠词:a , the等; 但以下情况可不加:表示不特指的、较抽象的概念:
This chapter will consider the characteristics of step polymerization in detail. An understanding of the relative ease of cyclization or linear polymerization comes from a variety of sources.Different polymers are synthesized to yield various mechanical behaviors by the appropriate combinations of crystallinity, crosslinking, Tg, and Tm..但需注意这些单词前加冠词也是经常见到的,这是由它在句中的含义决定的(如有一定的特指意义):Polyisoprene is a typical elastomer – it is amorphous, easily crossed, has a low Tg (-73°C) and a high Tm (14°C).
◆◆目录、标题中通常省略冠词:
1 Introduction
1-1 Types of Polymers and Polymerizations…
1-4 Molecular Weight
1-5 Physical State
图、表的题目中有时可省略冠词:Fig. 2-2 Second order plot of the self-catalyzed polyesterification of adipic acid with diethylene glycol at 166 °C.……Fig. 8 Dependence of the ease of cyclization on the size of the ring.化学药品、化学物质前通常不加冠词:The polymerization is catalyzed by protonic or lewis acids although a wide variety of base catalysts such as calcium acetate and antimony trioxide can also be used.图中的横、纵坐标的名称前不加冠词。
D. 大小写:请注意以下结构的大、小写:当提及具体第几章、节;图、表;方程式时,首个字母通常要大写。As discussed in Chapter 2, ……In Section 1.2, we ……As shown in Figure 1, ……The results are listed in Table 3.当不指明是第几章、节;图、表;方程式时,首个字母如在句中通常用小写。In the previous chapter, ……As shown in this figure, ……
E. 缩写:以下全名和缩写在文中通常视为同等,可以互换。
Figure Fig. Figures Figs.
Table Tab.
Chapter Chap.
Section Sec.
Equation Eq. Equations Eqs.
F. 一些常用词汇用法
◆◆research, study, investigate:research可做名词、动词,但通常做名词用,很少见到动词的用法。句中需要动词时常用study或investigate来表达。
◆◆detail/detailed:The properties of this compound were studied in detail.//The detailed properties of this compound were studied.//The details of the properties of this compound were studied.
◆◆follows/following:The results are as follows: ……//We got following results: ……
◆◆increase, decrease:均可做名词和动词,We can observe an increase in the reaction rate.//The reaction rate increases.
◆◆focus, concentrate:focus: n. , v. The focus of this paper is ……This paper focuses on ……Our study focuses on ……We focus our study on ……Our study is focused on ……concentrate: v. We concentrate our study on ……Our study is concentrated on ……
◆◆effect, affect:effect: n. //affect: v.
◆◆compose, consist:A is composed of B and C.//A consists of B and C.
◆◆increase, improve:increase: 主要指数值上的增加。improve: 主要指性质的增加、改善。
G. 名词修饰:在学术文章中,很多时候会用到直接用名词做修饰,而不用’s 或 …… of …… 的形式。常见的这类词有:reaction rate;reaction rate constant;reaction temperature;reaction condition
molecular weight distribution……
H. 分词修饰:the reaction we studied;the temperature used;the nonlinearity observed。所有格:非人的所有格用……of……, 而不用……’s 。
省部重点实验室
第21楼2010/11/19
第三部分 投稿
一、拟投期刊的选择:
(1)选用SCI收录期刊。目前SCI收录核心刊 3000种,加上增补期刊约 5600种。研究者可事先将SCI中自己感兴趣的期刊找出来备用。
(2)利用SCI收录期刊的影响引子(Impact Factor)来选择期刊。期刊的影响因子是该刊前2年发表的文献在当前的平均被引次数。《科学》、《自然》影响因子很高,SCI收录中国期刊影响因子都在1.00以下。期刊影响因子愈大,有用信息愈多。作者可根据期刊的影响因子排名决定投稿方向。
(3)利用学科带头人的影响或国际学术交流的条件,物色最了解中国学术研究、信任中国学者的那部分期刊投稿。SCI选用的期刊中约 1 / 3为美国期刊,因而要注意选美国期刊。
二、如何准备投稿?
选择适合刊物投稿:从杂志homepage下载Instruction for Author,按投稿要求,如投稿份数、论文体例、长度、图表、参考文献引法、配图说明(Figure legends)等,逐条遵循。Letter to editor-in-chief : ①声明文稿权转让;②未一稿多投,和在稿件未作出决定前不准备一稿多投;③所有列出作者均对文稿有确切贡献;④文稿内容真实,无作伪;⑤所有作者均已阅读文稿,且同意送稿;⑥通信作者地址、电话、Fax、e-mail;⑦通信作者签名。勿一稿多投。
Title page 的式样如下:
Peroxisome Proliferation-Activated Receptor-g Ligands Ameliorate Experimental Autoimmune Myocarditis
Zuyi Yuan, MD, PhD; Yan Liu, MD; Yu Liu, MD; Jijun Zhang, MD; Chiharu Kishimoto, MD, PhD*; Yanni Wang, MD; Aiqun Ma, MD, PhD; Zhiquan Liu, MD.
Department of Cardiovascular Medicine, First Hospital of Xi'an Jiaotong University, Xi'an, Shaanxi 710061, China; *Department of Cardiovascular Medicine, Graduate School of Medicine, Kyoto University, Kyoto 606-8501, Japan
First author's surname: Yuan
Running head: PPARg ligands ameliorate myocarditis
Supported by Natural Science Foundation of China (30170371)
Address correspondence to:
Zuyi Yuan, MD, PhD
No.1 Jiankang Road, Xi'an, Shaanxi 710061, China
Tel: +86-29-532-4021 Fax: +86-29-5263190
E-mail: zuyiyuan@mail.xjtu.edu.cn
三、向国外生物医学期刊投稿需注意
A. 期刊选择:
英文生物医学期刊种类繁多,选择一本恰当的期刊并非一件易事,然而这是论文得以发表的一个重要环节。选择期刊应考虑的因素:论文主题是否在刊物征稿范围内?论文格式是否符合刊物要求?论文是否符合刊物的一贯口味?关于期刊的声望(prestige)问题:期刊学术水平高其声望就高;反之声望则低。生物医学工作者都希望科研成果发表在有声望的高质量生物医学期刊上。选择期刊的方法:如果论文主题在一个很窄的分支学科内,那么选择范围只能限制在几种刊物;如果论文信息交叉了几个研究领域,则可有许多种选择。无论是哪种情况,先列出一个简单拟选期刊表,然后逐一对进行比较筛选,作出最后抉择。
B. 阅读和使用投稿须知:
(1)读刊头(masthead statement,通常放在期刊前面的文题页上),以了解刊名、简单的办刊宗旨、编辑委员会组成、编辑部成员、出版商及其联系地址等。
(2)浏览目录(table of contents),确定该刊物是否发表你研究领域的文章及发表的比例有多大。
(3)注意栏目设置,确定拟投稿件的栏目。
(4)看拟投栏目文章的范例,了解撰写要求及格式。
(5)某些期刊刊登投稿和接收日期(submitted and accepted dates),可据此计算论文发表周期。
广告数量可间接判断期刊质量。因为广告公司都愿意将金钱投到质量高、影响大的期刊上。
(7)通过11或12月份出版的杂志最后几页上的“所有权、管理和发行声明”(statement of ownership,management,and circulation)查找期刊发行量。
核查有无北美和欧洲以外国家作者撰写的文章。
(9)有些期刊还刊登报道计划,作者可依此拟订自己的投稿计划。
C. 投稿注意事项:
当决定了论文主题,确定了读者群,并选定了拟投期刊后,论文文献检索工作即便完成。下一步是确定论文作者、查看期刊的“投稿须知”,并将研究结果的原始资料收集在一起开始撰写论文。论文撰写是一项艰苦的工作,并非一稿就能完成,往往需要反复易稿(修改)才能使文章达到投稿的要求,即"5C"—正确 (correctness)、清楚(clarity)、简洁(concision)、完整(completion)和一致(consistency)。
D. 投稿:论文的最后一稿准备好后,就可向国外投稿。一般来说,投稿程序分以下三步。
(1) 准备投稿信 (covering letter,submission letter):生物医学期刊的编辑往往需要一些有关作者及其论文的信息,而作者也希望给编辑提供一些有助于其全文送审及决策的信息。这些信息都应该包括在投稿信中。投稿信应包括以下几方面的内容:文题和所有作者的姓名;稿件适宜的栏目;为什么此论文适合于在该刊而不是其它刊物上发表?关于重复或部分发表或已投它刊的说明;不能转让版权的说明(如美国联邦政府雇员);建议审稿人及因存在竞争关系而不宜做审稿人的名单;通信作者(corresponding author)的姓名、详细地址、电话和传真号码、e-mail地址;能否付出版费(版面费、彩图费)的说明(如果该刊收取版面费和彩图费);希望核校校样或稿件若不接收退回原稿的要求(有的期刊在“投稿须知”中约定,除非作者在投稿信中提出要求,否则原稿不退还给作者)。投稿信举例:
Dear Dr.:
Enclosed are three copies of a manuscript. by Rose N .Dipaola,Donna A.Gallo,and Tom N.Roberts titled ”Hepatitis C Virus Infection in Long-Term Transfusion Patients”. It is submitted to be considered for publication as a ”Original Article" in your journal.This paper is~?Neither the entire paper nor any part of its content has been published or has been accepted elsewhere. It is not being submitted to any other journal.
We believe the paper may be of particular interest to the readers of your journal because the study it reports stated the HCV infection rate among long-term transfusion patients is higher than that of the general population and of short-term transfusion patients.
Correspondence and phone calls about the paper should be directed to Rose N.Dipaola at the following address,phone and fax number,and e-mail address:
Rose N .Dipaola,MD
Institute of Internal Medicine
Cleveland Clinic Foundation
9500 Euclid Ave.
Cleveland,OH44195,USA
Tel:1-216-444-5360
Fax:1-216-444-9580
E-mail:dipao@cesmtp .ccf. Org
Thanks very much for your attention to our paper.
Sincerely yours,
Rose N.Dipaola
(2) 稿件包装:所谓稿件包装是指将稿件及其拟投期刊所需的伴随资料一并装人信封。一般应按以下顺序备齐资料:投稿信;刊物要求的稿件(包括文题页、文摘页、正文、致谢、参考文献、图注、表及图)拷贝份数,每份图单独装一个信封;版权转让声明;与稿件内容有关资料的拷贝(如学术会议报告论文或已发表的摘要等材料);通知稿件收到的明信片或有作者地址并贴足邮资的信封(适用于不发收稿回执的期刊);致谢和使用病人照片或引用私人通信的书面同意材料的复印件;有些期刊要求附稿件对照检查表。以上材料不要用订书钉固定,以免途中因订书钉移动而损坏稿件;但可以用大型曲别针固定,照片可以在信封中夹硬纸片保护。
(3) 稿件邮寄:邮寄稿件应注意:应至少自留一份打印底稿;信封要足够大,并足够结实;正确的投稿地址及收稿人(“投稿须知”中常有说明,多要求直接寄给主编);照片不可过大,最大不超过8.5英寸x11英寸?贴足邮票;航空邮寄;以打印稿(hard copy)投稿。几乎所有的英文生物医学期刊均不接受传真(fax)投稿,某些期刊仅允许一些没有图表的短文或“给编辑的信”通过电子邮件(e- mail)投稿,长篇论著、研究报告等文章决定刊用后方接受软磁盘。以上信息可以从“投稿须知”中获得、有的期刊在“投稿须知”中特别指出投稿地址与订刊或订单行本地址不一样,以免造成时间耽搁 。
