我认为:框架指令要求是对食物感观的评定,模拟溶液不能完全代替实际接触的食物。所以即使作oveall migration 测试时发生了脱色现象,也不能判断fail。可以在结论中加上remark。
学无止境(xarshao) 发表:欧盟1935-2004-EC中有这么一个条款
Article 3
General requirements
1. Materials and articles, including active and intelligent mate-
rials and articles, shall be manufactured in compliance with good
manufacturing practice so that, under normal or foreseeable con-
ditions of use, they do not transfer their constituents to food in
quantities which could:
(a) endanger human health;
or
(b) bring about an unacceptable change in the composition of
the food;
or
(c) bring about a deterioration in the organoleptic characteris-
tics thereof.
要求不会对食物成分发生改变,不会导致感官的劣变,
这个算是对感官的要求吧
