wangxichuang
第31楼2010/11/19
高麦东西贵啊,不过我们用的和你的不一样
poplar_yang
第32楼2010/12/01
有键何不试试?usually keep press the green button for 5 second, then you can see the digits flash, that is for you to set up temperature, you can use arrow. refer to page 10 of manual .
zhuxixi
第33楼2010/12/01
见识了,没见过
