jy010422
第13楼2011/02/26
But how to eliminati the bubble?Thanks for your guidance!
zlignc
第14楼2011/02/26
1. Create some back pressure after the dectector and suddenly release the pressure. Repeat this several time.
2. Flow pure organic solvent with how flow rate through your flow cell.
3. Use syringe to push methanol through the the flow cell.
You can try the above methods. You can also take out the flow cell to check the presend of bubble.
