feixiong5134
第11楼2006/01/02
centripetal force 向心力
Cephalosporins 头孢菌素类 AT
Cerenkov radiation 切论科夫辐射
Cerium [Ce] 铈
Cerivastatin; its salts 西立伐他汀;其盐类 PP-S1,S3
certification 认证
certified colour 合法食用染料;检定食用染料
Certified Reference Materials [CRM] 经验证标准品
Cesium [Cs] 铯
chain reaction 连锁反应
charcoal tube 活性炭管
Chelation Ion Chromatography 钳合离子色谱法
Chemical Analyst 化学分析主任
chemical composition 化学成分
Chemical Ionization [CI] 化学电离
Chemical Oxygen Demand [COD] 化学需氧量
chemical properties 化学性质
chemical reaction 化学反应
Chemical Sciences Section 化学组
Chemical Weapons Convention Section 化武公约组
chemical yield 化学产额
chemiluminescence 化学发光
Chemist 化验师
Chenodeoxycholic Acid 鹅去氧胆酸
Chief Chemist 总化验师
chiller 致冷器
China National Environmental Monitoring Centre 中国环境监测总站
Chinese Medicinal Materials [CMM] 中药材
Chinese Medicines Section 中药组
chiral column 手性柱
Chlofenamic acid; its salts 氯灭酸;其盐类 PP-S1,S3
Chloral; its addition and its condensation products; any compound with any substance falling within this item 氯醛;其添加制品及其缩合制品;含有任何属此项范围内的物质的化合物 PP-S1,S3
Chlorambucil 苯丁酸氮芥 PP-S1, S3
Chloramphenicol 氯霉素 AT
Chloramphenicol palmitate 无味氯霉素 AT
Chlordiazepoxide; its salts 氯氮□;其盐类 PP-S1,S3
Chlorinated pesticides 有机氯农药
Chlorine [Cl] 氯
Chlormethiazole; its salts 氯美□唑;其盐类 PP-S1,S3
Chlormezanone 氯美扎酮 PP-S1,S3
Chloroacetic acid 氯醋酸
Chloroacetyl chloride 氯乙醯氯
Chlorobenzene 氯苯
Chlorodifluoroethane 氯二氟乙烷
Chlorodifluoromethane 氯二氟甲烷
Chlorodifluoropropane 氯二氟丙烷
Chlorodiphenyl (42% chlorine) 氯联苯(42% 氯)
Chlorofluoroethane 氯氟乙烷
Chlorofluoromethane 氯氟甲烷
Chlorofluoropropane 氯氟丙烷
Chloroform 氯仿 PP-S1,S2
Chlorogenic Acid 氯原酸
Chlorohexafluoropropane 氯六氟丙烷
Chloromethane (Methyl chloride) 氯甲烷(甲基氯)
Chloropentafluoropropane 氯五氟丙烷
Chlorophyll - a 叶绿素?
Chloroquine; its salts; its derivatives; their salts 氯□;其盐类;其衍生物;它们的盐类 PP-S1,S3
Chlorotetrafluoroethane 氯四氟乙烷
Chlorotetrafluoropropane 氯四氟丙烷
Chlorothiazide and other derivatives of benzo-1,2,4-thiadiazine-7-sulphonamide-1,1-dioxide, whether hydrogenated or not; their salts 氯□□及1,1-二氧化苯并-1,2,4-□二□-7-磺胺的其他衍生物,不论其经氢化与否;它们的盐类 PP-S1,S3
Chlorotrifluoroethane 氯三氟乙烷
Chlorotrifluoropropane 氯三氟丙烷
Chlorpheniramine maleate 扑尔敏
Chlorphenoxamine; its salts 氯苯沙明;其盐类 PP-S1,S3
Chlorphentermine; its salts 对氯苯丁胺;其盐类 PP-S1,S3
Chlorpropamide; its salts 氯磺丙□;其盐类 PP-S1,S3
Chlorprothixene and other derivatives of 9-methylenethiaxanthen; their salts 氯普□吨与9-甲基硫□的其他衍生物;它们的盐类PP-S1,S3
Chlortetracycline 金霉素 AT
Chlorthalidone and other derivatives of ortho-chlorobenzenesulphonamide 氯□酮及邻氯苯磺胺的其他衍生物 PP-S1,S3
Chlorzoxazone 氯唑沙宗 PP-S1,S3
chromatography 层析法
Chromium [Cr] 铬
Chromium trioxide 三氧化铬
Chromomycin 色霉素 AT
chromosome 染色体
feixiong5134
第12楼2006/01/02
Chrysophenol 大黄酚
Chrysotile 温石棉;白石棉
Chuanxiongzine hydrochloride 盐酸川芎□
Chymopapain 糜木瓜□ PP-S1,S3
Cicletanine; its salts 西氯他宁;其盐类 PP-S1,S3
Cidofovir; its salts Cidofovir;其盐类 PP-S1,S3
Cigarette Testing Machine 卷烟测试仪
Cilazapril; its salts 西拉普利;其盐类 PP-S1,S3
Cimetidine 西咪替丁
Cineole 桉油精
Cinepazide; its salts 桂□齐特;其盐类 PP-S1,S3
Cinnamic Acid 肉桂酸
Cinobufagin 华蟾酥毒基
Ciprofibrate; its salts 环丙贝特;其盐类 PP-S1,S3
Ciprofloxacin; its salts; its esters 环丙沙星;其盐类;其酯类 PP-S1,S3
circulator 循环器
cirrhosis 肝硬化
Cisapride 西沙必利 PP-S1,S3
Cisatracurium besylate 顺式苯磺酸阿曲库胺 PP-S1,S3
Cisplatin 顺铂 PP-S1,S3
Citalopram; its salts 西□普兰;其盐类 PP-S1,S3
Cladribine 克拉屈滨 PP-S1,S3
class characteristic 一般特征(文件)
clathrates 笼形包合物
Clavulanic Acid 克拉维酸 AT
clean room 超净室
cleanup 净化
clearance 清除
Clenbuterol hydrochloride 盐酸克仑特罗
client's complaints 委托人申诉
Clindamycin 克林霉素 AT
Clioquinol 氯碘羟□ PP-S1,S2,S3
Clobazam 氯巴占 DD
Clodronic acid; its salts; its esters 氯屈膦酸;其盐类;其酯类 PP-S1,S3
Clofibrate 氯贝特 PP-S1,S3
Clomiphene citrate 枸橼酸氯米芬 PP-S1, S3
Clomiphene; its salts 氯米芬;其盐类 PP-S1,S3
Clomipramine; its salts; its derivatives; their salts 氯米帕明;其盐类;其衍生物;它们的盐类 PP-S1,S3
Clonazepam 氯硝西泮 DD
clone 克隆
Clonidine hydrochloride 盐酸可乐定 PP-S1, S3
Clonidine: its salts 可乐定;其盐类 PP-S1,S3
Clonitazene 氯尼他秦 DD
Clonitazene; its salts 氯尼他秦;其盐类 PP-S1,S3
Clopidogrel; its salts 氯□多;其盐类 PP-S1,S3
Clorazepate 安定羧酸 DD
Clorexolone 氯索隆 PP-S1,S3
Cloridarol 氯达香豆素 PP-S1,S3
Clorprenaline; its salts 氯丙那林;其盐类 PP-S1,S3
Clothiapine 氯□平 PP-S1,S3
Clotiazepam 氯□西泮 DD
Clotrimazole 克霉唑 PP
Clotrimazole; its salts 克霉唑;其盐类 PP
Cloxacillin sodium 邻氯青霉素钠 AT
Cloxazolam 氯恶唑仑 DD
Coal tar pitch volatiles, as Cyclohexane solubles 煤焦油沥青挥发物,以可溶于环己烷量算
Cobalt [Co] 钴
Coca, alkaloids of 古柯生物硷 PP-S1
Cocaine 可卡因 DD, PP-S1
Code of Federal Regulations 美国联邦法规
Codeine 可待因 DD
Codeine; its esters and ethers 可待因;其酯类及醚类 PP-S1
Codex Alimentarius Commission 联合食物标准计划食品法典委员会
co-dominant gene 等显性基因
Codoxime 可多克辛 DD
coefficient of friction 磨擦系数
Coinage Ordinance 硬币条例
Colaspase 左旋天冬□胺□ PP-S1,S3
Colchicum, alkaloids of 秋水仙生物硷 PP-S1,S3
Cold Vapour Atomic Absorption Spectroscopy 冷原子吸收法
Colfosceril; its salts 棕榈酸可夫色尔;其盐类 PP-S1,S3
Colistin 多粘菌素 E AT
collaborative trials 合作尝试
Collagen, purified 精制胶原 PP-S1,S3
collective dose 集体剂量
collision 撞击
Collision Induced Decomposition [CID] 碰撞诱导分解
colorimeter 色度计
colour sensitivity of films 菲林感光度
Colouring matter in Food Regulations 食物染色料规例
colouring substances 染料
column 柱
Column Chromatography 柱色层法
column head pressure 柱头压
Combined Paternity Index [CPI] 总和父权指数
Combustion-Infrared Method 燃烧氧化-红外吸收法
feixiong5134
第13楼2006/01/02
committed dose 约定剂量
common authorship 同一人书写
common in nature 共同特征;共同性质
common ingredient 共同成份
composite sample 综合样本
compound 化合物
compressor 压缩机
Compton effect 康普顿效应
concentrated acids 浓酸
concentration 浓度
concentration factor 浓集因数,富级比
concentration technique 富集法
Conductivity Meter 电导率计
confidence interval 置信区间
confidence limit 置信限
conformity 合格(符合)
Coniine 毒芹硷 PP-S1,S3
conservation of energy 能量不变原理
conservation of momentum 动量不变原理
consistometer 浓度测试器
Consumer Goods Safety Ordinance 消费品安全条例
contact damage 接触损坏
contaminant 污染物
contamination 污染
content 含量
contingency plan 应变计划
continuum 连续谱
contract review 合同评审
Contrast media, the following ; their salts; any compound with any substance falling within this item; when contained in preparations for parenteral use - 造影剂如下,它们的盐类;含有任何属此项范围内的物质的化合物;包含在供注射用的制剂时 -- PP
control 对照物(实验中)
control chart 质量评估图
control level 控制水平
Control of Chemicals Ordinance 化学品管制条例
control sample 对照试样
Controlled document 受控文件
Controlled Drugs Section 受管制药物组
conventional serology 常规血清学
Coomassie blue staining 考玛斯亮蓝染色
Copper [Cu] 铜
copybook form 字帖形体
cornet 金圈
coronary thrombosis 冠状动脉血栓形成
corrective actions 纠正措施
correlations 相互关系
corrosive fluid 腐蚀性的流体
Corticorelin; its salts 可的瑞林;其盐类 PP-S1,S3
Corticotrophins 促皮质素类 (促肾上腺皮质激素) PP-S1,S3
Corynebacterium parvum 短小棒状杆菌菌苗 PP-S1,S3
Cotarnine 可他宁 PP-S1,S3
cotton dust, raw 原棉尘
cotton swab 药棉
Coulomb interaction 库仑相互作用
counter immunoelectrophoresis 对流免疫电泳
countermeasure 相应措施;干预措施
counting 计数
couple 力偶(物理);电偶
crank 曲柄轮
crease 褶线
Creosote obtained from wood 由树木所得之木馏油 PP-S2
Cresol, all isomers 甲酚,所有异构体
crime scene 罪案现埸
Crimes Ordinance 刑事罪行条例
Criminalistics and Quality Management Group 刑事科学及品质管理科
Cristobalite 方英石
critical 临界的
critical velocity 临界速度
Crocein Scarlet 7B 藏猩红 7B
Crocidolite 青石棉;蓝石棉
cross mark (his mark) 交叉痕迹
cross section 截面
cross-over electrophoresis 交叉电泳
Croton,oil of 巴豆油 PP
crowbar 铁棍;铁撬
crown ether 冠醚
cryoscope 冰点测定器
crystal 晶体
crystalline solid 结晶体
Cumene 枯烯
Cumene hydroperoxide 过氧化氢枯烯
cupel 烤钵;灰皿
cupellate 灰吹
cupellation method 烤钵试金法
Curare, alkaloids of; curare bases 箭毒生物硷;箭毒基质 PP-S1,S3
Curculigoside 仙茅□
Curium [Cm] 锔
cursive style 草书
cyanide 氰化物
cyanosis 发绀;青紫
Cyclamate 环氨酸盐
Cyclarbamate 环拉氨酯 PP-S1,S3
Cyclizine 赛克利□ PP
Cyclobenzaprine; its salts 环苯扎林;其盐类 PP-S1,S3
Cyclofenil 环芬尼(双醋环烷) PP-S1,S3
Cyclohexane 环己烷
Cyclohexanol 环己醇
Cyclohexanone 环己酮
Cyclohexanone hydroperoxide 过氧化氢环己酮
Cyclohexanone peroxide 过氧化环己酮
Cycloserine 环丝氨酸 AT
Cycrimine; its salts 赛克立明;其盐类 PP
Cyfluthrin 百树菊脂
Cyhalothrin 三氟氯氰菊脂;功夫
Cypermethrin 氯青菊脂
Cytarabine; its salts 阿糖胞□;其盐类 PP-S1,S3
