yxcxzqx
第11楼2006/01/06
ALPHABETIC INDEX
A
Accuracy A2
Accuracy A3
Accuracy class 4.23
Accuracy class A9
Accuracy of a measuring system A3
Accuracy of measurement A2
Adjustment 3.11
Adjustment of a measuring system 3.11
B
Base measurement unit 1.11
Base quantity 1.5
Base unit 1.11
Bias A14
Bias of a measuring system A14
C
Calibration 2.22
Calibration hierarchy 2.23
Calibration of a measuring system 2.22
Calibrator 5.12
Certified reference material 5.14
Check device 5.10
Check measurement device 5.10
Coherent derived unit 1.13
Coherent system of units 1.15
Combined standard measurement uncertainty 2.16
Combined standard uncertainty 2.16
Commutability of a reference material 5.15
Comparability 2.29
Comparability of measurement results 2.29
Compatibility 2.30
Compatibility of measurement results 2.30
Conservation of a measurement standard 5.11
Conventional quantity value 1.19
Conventional reference measurement scale 2.9
Conventional reference scale 2.9
Conventional value 1.19
Conventional value of a quantity 1.19
Conversion factor between units 1.25
Correction 2.32
Coverage factor 2.17
Coverage interval 2.19
Coverage probability 2.10
CRM 5.14
D
Datum error A11
Datum error of a measuring system A11
Dead band 4.16
Dead band of a measuring system 4.16
Definitional measurement uncertainty 2.12
Definitional uncertainty 2.12
Derived quantity 1.6
Derived unit 1.12
Detector 3.9
Dimension 1.7
Dimension of a quantity 1.7
Dimensionless quantity 1.8
Discrimination threshold 4.15
Displaying device 3.7
Drift 4.18
Drift of a measuring system 4.18
E
Error A5
Error of indication A6
Error of measurement A5
Etalon 5.1
Expanded measurement uncertainty 2.18
Expanded uncertainty 2.18
I
Indicating measuring instrument 3.6
Indication 4.1
Indication interval 4.2
Indication of a measuring system 4.1
Influence quantity 2.31
Input quantity to a measurement function 2.34
Instrument uncertainty 4.22
Intermediate measurement precision 2.39
Intermediate precision 2.39
Intermediate precision condition 2.38
Intermediate precision condition of measurement 2.38
International System of Units 1.16
International systems of quantities 1.4
Intrinsic error A13
Intrinsic error of a measuring system A13
Intrinsic measurement standard 5.9
Intrinsic standard 5.9
ISQ 1.4
L
Limit of error A10
Limiting condition 4.9
Limiting condition for a measuring system 4.9
M
Material measure 3.2
Maximum permissible error A10
Measurand 2.3
Measurement 2.1
Measurement error
Measurement function 2.33
Measurement method 2.5
Measurement precision 2.35
Measurement principle 2.4
Measurement procedure 2.6
Measurement repeatability 2.37
Measurement reproducibility 2.41
Measurement result 2.10
Measurement scale 2.8
Measurement standard 5.1
Measurement system 3.5
Measurement uncertainty 2.11
Measurement unit 1.9
Measuring chain 3.4
Measuring instrument 3.1
Measuring interval 4.6
Measuring system 3.5
Measuring transducer 3.3
Method of measurement 2.5
Metrological traceability 2.24
Metrological traceability chain 2.25
Metrological traceability to a measurement unit 2.26
Metrological traceability to a unit 2.26
Metrology 2.2
Multiple of a unit 1.17
N
National measurement standard 5.2
National standard 5.2
Nominal indication interval 4.3
Nominal interval 4.3
Nominal quantity value 4.5
Nominal value 4.5
Numerical quantity value 1.20
Numerical quantity value equation 1.23
Numerical value 1.20
Numerical value equation 1.23
Numerical value of a quantity 1.20
O
Optimum condition 4.11
Optimum condition for a measuring system 4.11
Ordinal quantity 1.26
P
Precision 2.35
Primary measurement procedure 2.7
Primary measurement standard 5.3
Primary procedure 2.7
Primary standard 5.3
Principle of measurement 2.4
Q
Quantities of the same kind 1.2
Quantity 1.1
Quantity calculus 1.24
Quantity dimension 1.7
Quantity equation 1.21
Quantity of a dimension one 1.8
Quantity value 1.10
R
Random error A7
Random error of measurement A7
Rated operating condition 4.8
Rated operating condition for a measuring system 4.8
Reference condition 4.10
Reference condition for a measuring system 4.10
Reference data 5.16
Reference material 5.13
Reference measurement standard 5.5
Reference quantity value 5.18
Reference standard 5.5
Reference value 5.18
Relative error of measurement
Repeatability 2.37
Repeatability 4.21
Repeatability condition 2.36
Repeatability condition of measurement 2.36
Repeatability of a measuring system 4.21
Reproducibility 2.41
Reproducibility condition 2.40
Reproducibility condition of measurement 2.40
Resolution of a displaying device 4.14
Resolution of a measuring system 4.13
Result of measurement 2.10
RM 5.13
S
Scale 3.10
Scale of a displaying device 3.10
Secondary measurement standard 5.4
Secondary standard 5.4
Selectivity 2.42
Selectivity of a measuring system 2.42
Sensitivity 4.12
Sensitivity of a measuring system 4.12
Sensor 3.8
Span 4.4
Span of a nominal interval 4.4
Specificity 2.43
Specificity of a measuring system 2.43
Stability 4.17
Stability of a measuring system 4.17
Standard 5.1
Standard measurement uncertainty
Standard reference data 5.17
Steady state condition 4.7
Steady state condition for a measuring system 4.7
Step-change response time 4.20
Step-change response time of a measuring system 4.20
Submultiple of a unit 1.18
System of units 1.14
Systematic error A8
Systematic error of measurement A8
Systems of quantities 1.3
T
Target measurement uncertainty 2.21
Target uncertainty 2.21
Traceability chain 2.25
Transfer device 5.8
Transfer measurement device 5.8
Travelling measurement standard 5.7
Travelling standard 5.7
True value A1
True value of a quantity A1
Trueness A4
Trueness of measurement A4
Type A evaluation 2.13
Type A evaluation of measurement uncertainty 2.13
Type B evaluation 2.14
Type B evaluation of measurement uncertainty 2.14
U
Uncertainty 2.11
Uncertainty of measurement 2.11
Unit 1.9
Unit equation 1.22
Unit of measurement 1.9
V
Validation 2.28
Value 1.10
Value of a quantity 1.10
Variation due to an influence quantity 4.19
Verification 2.27
W
Working interval 4.6
Working measurement standard 5.6
Working standard 5.6
Z
Zero adjustment 3.12
Zero adjustment of a measuring system 3.12
Zero error A12
Zero error of a measuring system A12
