rock_rock
第29楼2011/03/25
Login is an IT jargon that usually used as a noun. When use the term in verb form, should separate it as log in.
In reality, the whole sentence is quite Chinglish style. I'll re-write it as:
I log in the Instrument BBS right after I turned on my computer
