去年冬天
第11楼2011/04/06
9.Nickel Release(镍释放)
EN 1811 EN12472
10.chromium (六价铬,Cr6+) GB/T 17593.3
DIN 53314 DIN 54020
11.Organic tin compounds(TBT、DBT、TPhT) (有机锡化合物)
GB/T 20385
12.Phthalates(DINP, DNOP, DEHP, DIDP, BBP, DBP) PVC增塑剂 (邻苯甲酸酯)
GB/T 20388
13. chlorinated benzenes and toluene’s 氯苯和甲苯(原 有机氯载体)
GB/T 20384
14. Pesticides( 30items)杀虫剂( 30种)
GB/T 18412.1--3
15.Determination of odors 异味的测定
OKEO TEX-200
去年冬天
第12楼2011/04/06
组织分析
1.Yarn count(线密度/纱支数)
ASTM D 1059 ISO 7211/5
BS 2865 JIS L-1096
FZ/T 01093
2.Fabric Weight per unit area & length (单位面积和单位长度织物重量)
ASTM D3776 ISO 3801
DIN/BS EN 12127
AS 2001.2.13
JIS L-1018(Knit) JIS L-1096(Woven)
GB/T 4669
3.Fabric Thickness 织物厚度
ASTM D1777 ISO 5084
DIN/BS EN ISO 5084
GB/T 3820
4.Threads per Unit Length Woven & Knitted (密度)
ASTM D3775 ASTM D3887
DIN/BS EN 1049.2 DIN 53853
ISO 7211/2 JIS L-1096
AS 2001.2.5 BS 2862
GB/T4668
5.Measuring Bow & Skew(扭曲及歪斜度)
ASTM D 3882 BS 2819
JIS L-1096 GB/T 14801
6.Fabric Width(布幅宽)
ASTM D 3774 ISO 3932
JIS L-1096 GB/T 4667
7.Fabric length(布长度)
ASTM D 3773 ISO 3933
JISL 1096 GB/T 4666
去年冬天
第13楼2011/04/06
尺寸稳定性(缩水率)及相关测试
1.Dimensional Stability to Washing(水洗缩率)
a. Washing Temp.up to 70℃ 水洗温度70℃或以下
b.Washing Temp.up to 70℃ to boil水洗温度70℃至沸腾
AATCC 135 AATCC 150
ISO 6330 AS 2001.5.1
BS/DIN EN 6330
GB/T 8630
Each Additional Wash Cycle(每增加1次水洗)
2.Appearance After Laundering(水洗后外观)
a. Actual Laundering 实际洗涤
b. After Wash 洗涤后外观
AATCC 124 AATCC 143
AATCC 88B AATCC 88C
ISO 7768 ISO 7769
ISO 7770 GB/T 13769
GB/T 13770 GB/T 13771
3.Dimensional Stability to dry-cleaning(干洗缩率)
Commercial Dry-cleaning After 1Cycle 商业干洗1次
4.Appearance After Dry-cleaning(干洗后外观)
1 cycle Dry Cleaning 1次干洗
5.Spirality/Skewing of Fabric & Garment(织物和服装洗涤扭曲和弯斜)
AATCC 179
6.Dimensional Stability to Relaxation & Felting(松弛收缩和毡化收缩)
TM 31 FZ/T 70009
去年冬天
第14楼2011/04/06
色牢度测试
1.Washing 水洗
AATCC 61 ISO 105 C01~C06
BS/DIN EN ISO 105 C01~C06
AS 2001.4.15 JIS L 0844
GB/T 3921.1~3921.5
GB/T 12490
2.Perspiration(耐汗渍)
AATCC 15 ISO 105 E04
BS/DIN EN ISO 105 E04
JIS L 0848 AS 2001.4.17
GB/T 3922
3.Dry &Wet Crocking /Rubbing(耐摩擦)
AATCC 8 ISO 105 X12
DIN/BS EN ISO 105 X12
JIS L-0849 Type 1 Test
AS 2001.4.3 AATCC 116
GB/T 3920
4.Light(耐光照)
AATCC 16 ISO 105 B02
BS/DIN EN ISO 105 B02
JIS L 0843 GB/T 8427
a) 20 Fading Units 0r Below 20(20个褪色单位或以下)
去年冬天
第15楼2011/04/06
4 Grade 4 or Below 4 (灰卡4级或4级以下)
b) Each Additional 10 Fading Units or 10 hours
5.Water(耐水)
AATCC 107
ISO 105 E01
DIN/BS EN ISO 105 E01
AS 2001.4.8 JIS L 0846
GB/T 5713
6.Sea Water(耐海水)
AATCC 106 ISO 105 E02
BS/DIN EN ISO 105 E02
JIS L 0847 GB/T 5714
7.Chlorinated Water(耐氯水)
AATCC 162 ISO 105 E03
DIN/BS EN ISO 105 E03
AS 2001.4.5 GB/T 8433
8.Dry Cleaning(耐干洗)
AATCC 132 ISO 105 D01
DIN/BS EN ISO 105 D01 AS 2001.4.16
JIS L-0860 GB/T 5711
9.Actual Laundering(实际洗涤)
With Shrinkage Conducted(缩水率试验后)
a)Cold to 70℃(冷水至70℃)
b) Above 70℃(超过70℃)
去年冬天
第16楼2011/04/06
10.Commercial Dry-clean 商业干洗
11.Chlorine Bleaching(耐氯漂)
AATCC 188
12.Sweet &Saliva(耐唾液)
DIN53160
GB/T 18886
13.Dry Heat( 耐干热 )
AATCC 117 ISO 105 P01
BS/ DIN EN ISO 105 P01
JIS L 0879 GB/T 5718
14.Hot Pressing(耐热压)
AATCC 133 ISO 105 X11
BS/DIN EN ISO 105 X11 JIS L 0850
AS 2001.4.6 GB/T 6152
15.Water Spotting(耐水斑)
AATCC 104 ISO 105 E07
BS/DIN EN ISO 105 E07
JIS L 0853 AS 2004.4.4
GB/T 5717
16.Acid Spotting(耐酸斑)
ISO 105 E05
BS/DIN EN ISO 105 E05
JIS L 0851 AS2001.4.12
GB/T 5715
17.Alkaline Spotting(耐碱斑)
ISO 105 E06
BS/DIN EN ISO 105 E06
JIS L 0852 AS2001.4.12
GB/T 5716
18.Organic Solvents(耐有机溶剂)
ISO 105 X05
BS/DIN EN ISO 105 X05
GB/T 7074
