  • cissie-1986
    第21楼2011/04/16
    Thanks for you advice, however I have tried some sample with concentrations high enough for the test. Moreover, there is the MRLS for the medicine,
    the final detect limit should match it.
    poplar_yang(poplar_yang) 发表:maybe because your medicine concentration is too low
  • cissie-1986
    第22楼2011/04/16
    那我怎么能控制它阿,我现在特别着急解决我不出峰的问题,加了SDS效果有,但是根本不明显,也还是在溶剂峰里面...
    heguang(heguang) 发表:Be careful, some compounds can dissolve in high pH buffer, but it will encounter the danger of decompose in high pH.
  • kylabs
    第23楼2011/04/17
    SDS的浓度应该是需要优化的,你有没有从低到高优化SDS浓度?
  • litcatwang
    第24楼2011/05/19
    缓冲液里加有机溶剂试试
