chenwr
第61楼2011/04/15
学习了,看来适用面还是挺广的,谢谢
秋月芙蓉
第63楼2011/04/15
不错的检测技术,但目前应用有局限性,因为支持的标准方法不多见
poplar_yang
第67楼2011/04/15
I have to say sorry, because I never to do 钼 before, only suggestion is 2450度已是仪器默认设置的最高原子化温度, longtime to use this high temperature, this will make your machine die fast.
poplar_yang
第70楼2011/04/15
it looks like a whale, you know, whale does not breathe until it comes out of water, so the sample is preconcentrated in a room for some time, finally spray out ; do not spray for too long time otherwise the concentration will go down.
