joycat
第21楼2009/05/31
我也在头疼这个action limit,的确不好理解.
请问现在有人明白是什么意思了没?在线急切等待回复.
我把原文用附件上传了.
action limit出现在第10页至12页的Table 2A-Table 2l中,在第15页的A.10中有一个简单的说明,可惜我也没看明白.
EN71-9:2005
rock_rock
第23楼2010/09/07
纠偏界限
Action limits or action levels means the minimum and maximum values of a quality assurance measurement that can be interpreted as representing acceptable performance with respect to the parameter being tested. Values less than the minimum or greater than the maximum action limit or level indicate that corrective action must be taken by the facility. Action limits or levels are also sometimes called control limits or levels.
