谢谢
它山之石(graymice) 发表:Thank you for your reply.May I know what kind of SPME did you use?Are they 50/30 micrometer DVB/CAR/PDMS?I used PDMS/DVB 65 micrometer,but I didn't get good results and I found most spectrum were impurities and no other flavor substances found.
The following contents are too special to translate.
