推理很符合逻辑,但是……没对上。难度比较大。
iangie(iangie) 发表:圆斑直径3mm, 跟TEM 铜网吻合,
粉末suspension滴到铜网上, excessive water absorbed by filter paper, leaving particles on TEM grides.
Maybe your particle is magnetic, so you need another layer of carbon coating.......
这是为了给铜网上做Carbon film才放到滤纸上喷碳的..............是吧?
