symmacros
第11楼2011/09/17
Treatment for Insomnia
Acute insomnia may not require treatment. Mild insomnia often can be prevented or cured by practicing good sleep habits (see below). If your insomnia makes it hard for you to function during the day because you are sleepy and tired, your health care provider may prescribe sleeping pills for a limited time. Rapid onset, short-acting drugs can help you avoid effects such as drowsiness the following day. Avoid using over-the-counter sleeping pills for insomnia since they may have undesired side effects and tend to lose their effectiveness over time.
Treatment for chronic insomnia includes first treating any underlying conditions or health problems that are causing the insomnia. If insomnia continues, your health care provider may suggest behavioral therapy. Behavioral approaches help you to change behaviors that may worsen insomnia and to learn new behaviors to promote sleep. Techniques such as relaxation exercises, sleep restriction therapy, and reconditioning may be useful.
