请问具体怎样操作?
tulipylm0499(tulipylm0499)发表:agilent
Converting NIST user library to Agilent Chemstation User Library
The document below describes how to convert NIST libraries to Chemstation format.
In short, the procedure to convert a NIST library to Chemstation format is to export the NIST library as JCAMP file from the NIST search engine application. Subsequently, this JCAMP file can be imported by the Chemstation software to generate the equivalent .L Chemstation library.
