rock_rock
第14楼2011/11/17
According to these simple sentenses, there are only 2 settings - FAST/LOW NOISE. "a factor of 2" is just describing the filtering effect of the LOW NOISE setting. It doesn't mean that the user may control the degree of filtering freely.
poorlittle
第15楼2011/11/17
有点印像了。 In signal filtering, it seems that +/- 5dB (or 10dB ???) would increase or reduce the signal by 2 times ???
poorlittle
第16楼2011/11/17
A second thought, it seems that it may not be electronic signal filtering, but a chemical filtering.
所以先要区别是仪器程序还是气路或电路
chengjingbao
第17楼2011/11/17
这者经典的回复,没想到小小一句话,不光蕴藏着语言,而有许多专业的东西,我觉得这句话真贴近实际。修正中中!!!
再次表示感谢!
