小M
第11楼2011/12/06
Ab initio molecular dynamics study on the initial chemical events in nitramines: Thermal decomposition of CL-20 |
作者: Isayev, O (Isayev, Olexandr)1; Gorb, L(Gorb, Leonid)1,2; Qasim, M (Qasim, Mo)2; Leszczynski, J (Leszczynski, Jerzy)1,2 |
来源出版物: JOURNAL OF PHYSICAL CHEMISTRY B 卷: 112 期: 35 页: 11005-11013 DOI: 10.1021/jp804765m 出版年: SEP 4 2008 |
被引频次: 5 (来自 Web of Science) |
引用的参考文献: 56 [ 查看 Related Records ] 引证关系图 |
摘要: CL-20 (2,4,6,8,10,12-hexanitro-214,6,8,10,12-hexaazaisowurtzitane or HNIW) is a high-energy nitramine explosive. To improve atomistic understanding of the thermal decomposition of CL-20 gas and solid phases, we performed a series of A initio molecular dynamics simulations. We found that during unimolecular decomposition, unlike other nitramines (e.g., RDX, HMX), CL-20 has only one distinct initial reaction channel-homolysis of the N-NO2 bond. We did not observe any HONO elimination reaction during unimolecular decomposition, whereas the ring-breaking reaction was followed by NO2 fission. Therefore, in spite of limited sampling, that provides a mostly qualitative picture, we proposed here a scheme of unimolecular decomposition of CL-20. The averaged product population over all trajectories was estimated at four HCN, two to four NO2, two to four NO, one CO, and one OH molecule per one CL-20 molecule. Our simulations provide a detailed description of the chemical processes in the initial stages of thermal decomposition of condensed CL-20, allowing elucidation of key features of such processes as composition of primary reaction products, reaction timing, and Arrhenius behavior of the system. The primary reactions leading to NO2, NO, N2O, and N-2 occur at very early stages. We also estimated potential activation barriers for the formation of NO2, which essentially determines overall decomposition kinetics and effective rate constants for NO2 and N-2. The calculated solid-phase decomposition pathways correlate with available condensed-phase experimental data. |
