dosy
第28楼2012/05/31
CHAPTER 3
Testing for overall migration
Overall migration testing shall be performed under the standardised testing conditions set out in this chapter.
3.1.
Standardised testing conditions
The overall migration test for materials and articles intended for the food contact conditions described in column 3 of Table 3 shall be performed for the time specified and at the temperature specified in column 2. For test OM5 the test can be performed either for 2 hours at 100 °C (food simulant D2) or at reflux (food simulant A, B, C, D1) or for 1 hour at 121 °C. The food simulant shall be chosen in accordance with Annex III.
L 12/86 EN Official Journal of theEuropean Union 15.1.2011
If it is found that carrying out the tests under the contact conditions specified in Table 3 causes physical or other changes in the test specimen which do not occur under worst foreseeable conditions of use of the material or article under examination, the migration tests shall be carried out under the worst foreseeable conditions of use in which these physical or other changes do not take place.
