happyalife
第11楼2012/02/06
光纤附件
1.Smart Near-IR FiberPort
The accessory is used for samples at remote locations, samples that are not the
optimum shape/size to fit into a standard sample compartments, and the analysis
of polymers, pharmaceutical powders/tablets, foods, fabrics, and chemicals.
2.Smart Near-IR UpDRIFT
This is a top-loading diffuse reflectance accessory for the near-infrared
spectral region. The UpDRIFTTM uses a unique optical focusing system known as
CPC (compound parabolic concentrator) that virtually eliminates the specularly
reflected component, which distorts spectral results.
