ian.cheng
第12楼2012/03/17
organic tin
compounds
triphenyltin compounds
(TPT)
0.001
in articles
fragrance musk xylene 81-15-2 0.05
substances musk ketone 81-14-1 0.05
perfluorinated
compounds
Perfluorooctyl acid
(PFOA) and individual
salts and esters of PFOA
335-67-1, 3825-26-1,
335-95-5, 2395-00-8,
335-93-3, 335-66-0,
376-27-2, 3108-24-5
0.005
For textiles and
other coated
materials: 1 μg/m2
DTDMAC 68783-78-8
DODMAC/DSDMAC 107-64-2
surfactants
DHTDMAC 61789-80-8
in total 0.1
Bisphenol A 80-05-7 freely available
substance: 0.005
from [date],1
0.0025 from
[date]2
diethylhexylphtalate
(DEHP)
117-81-7 0.1
pentachlorphenol 87-86-5 0.1
other substances
triclosan 3380-34-5 0.001
For metals, the prohibition in the first subsection does not apply to natural occurrences in
coal, ore and ore concentrate.
ian.cheng
第13楼2012/03/17
II. Products and product groups that are not covered by the prohibition on
certain hazardous substances in consumer products
Section x-5. Arsenic and arsenic compounds
The prohibition in section x-4 on products containing arsenic and arsenic compounds
does not apply for:
- lead accumulators/sulphuric acid batteries,
- brass products,
- crystal and lead glass,
- ship-bottom paint and wood preservatives that are regulated in section 2-7 of these
regulations.
- arsenic-treated timber that is regulated in section 3-6 of these regulations.
- cosmetics and hygiene articles that are regulated in the Norwegian Cosmetics
Regulations (26 October 1995)
ian.cheng
第14楼2012/03/17
Section x-6. Lead and lead compounds
The prohibition in section x-4 on products containing lead and lead compounds does not
apply for:
- sailboat keels and ballast usages,
- glazings and enamels on products that must be presumed not to come into contact
with food products,
- lead diving belts,
- lead storage batteries,
- aviation fuels,
- paint that is regulated in section 2-5 of these regulations,
- ammunition, including shot pellet that is regulated in section 2-5 of these regulations,
- fuel that is regulated in section 3-16 of these regulations,
- packaging, batteries and electrical and electronic products and equipment that are
regulated in sections 3-11, 3-13 through 3-14 and 3-17 through 3-19 of these regulations.
ian.cheng
第15楼2012/03/17
Section x-7. Cadmium and cadmium compounds
The prohibition in section x-4 on products containing cadmium and cadmium compounds
does not apply for:
- electrical contacts for every application area that is surface-treated with cadmium or
cadmium compounds in order to ensure the reliability required for the device in which they
are installed,
- paints and lacquers with a high zinc content having a residual cadmium concentration of
up to 0.1 percent by weight,
- use of cadmium in pigments, as a stabiliser in products and with the surface treatment of
metal, provided its use is due to reasons of safety,
- galvanic anodes,
- cadmium in packaging, batteries and electrical and electronic products and equipment
that are regulated in sections 3-11, 3-13 through 3-14 and 3-17 through 3-19 of these
regulations.
ian.cheng
第16楼2012/03/17
Section x-8 Tributyltin and triphenyltin compounds
The prohibition in section x-4 on products containing tributyltin and triphenyltin
compounds does not apply for application areas that are regulated in sections 2-8 of these
regulations.
Section x-9. Musk xylene and musk ketone
The prohibition in section x-4 on products containing musk xylene and musk ketone does
not apply for washing agents that are regulated in sections 3-10 of these regulations.
ian.cheng
第17楼2012/03/17
Section x-10. The tensides DTDMAC, DODMAC/DSDMAC and DHTDMAC
The prohibition in section x-4 on products containing the tensides DTDMAC,
DODMAC/DSDMAC or DHTDMAC does not apply for washing agents that are regulated in
Section x-11. Bisphenol A
The prohibition in section x-4 on products containing bisphenol A does not apply for:
- jointless floors,
- brake fluid,
- thermal paper
- plastic fillings for dental treatment
ian.cheng
第18楼2012/03/17
Section x-12. DEHP
The prohibition in section x-4 on products containing DEHP does not apply for:
- construction materials outdoor use
- toys and children's products that are regulated in section 3-12 of these regulations.
Section x-13. Pentachlorophenol
The prohibition in section x-4 on products containing pentachlorophenol does not apply
for:
- textiles and leathers that are regulated in section 3-4 of these regulations.
Section §x-14. Triclosan
The prohibition in section x-4 on products containing triclosan does not apply for:
- Cosmetics and hygiene articles that are regulated in the Norwegian Cosmetics
