longwood
第21楼2012/04/24
我感觉这个好像完全是图像处理的问题,和TEM没什么太大的关系。楼主提到了TDS, 电子束能量扩散,但是公式里好像完全没有包括TDS, Cc引起的defocus的变化,scanning coil的噪声,样品及透镜电流的vabriation, 动力学衍射和样品厚度。似乎所有的因素都归到最终所获得的图像中了,变成了一个图像处理的问题。我不知道如果所有的因素考虑进去,最后的边缘模型是否还可以用楼主给出的那个公式来描述?
我印象中好像现在有些争论,说电镜分辨率只有多少,但是有些文章说测到原子的偏离要小一到两个数量级,然后有人争论这个是否是正确的。也许大家都不是做图像处理的,楼主或许多提供一些文献让大家学习学习?
perpetualcat68
第22楼2012/04/26
这个模式也还是个近似,考虑到了point spread function, defocus, background(含TDS), 但样品厚度的波动不在里面(通常对3种以下元素构成的样品可以做simulation.).还有STEM的"flyback error". 这两个因素还不太好用高斯函数来近似概括.
样品FIB加工后再用Gentel Ion Miller处理会好很多.
本来是对单个边缘近似描述的,比较成型了(很多测量都在用, x-ray等也在用), 后来我试着把它扩展到双边,最后干脆对整个扫描范围. 所用参数的物理含义并未改变.
如果将这个模式对映到diffusion就更有意思了.HRSTEM 的"Z-contrast"可以"转译"成元素分布,diffusion(Fick's law)本身也含有error function. 这方面还要多次进行EDX测量来评估.
这方面有很多相关的文献,困难点在于如何对4或5种以上元素组成的样品进行模拟. 对3种元素的分布描述已很成熟了.TEM/STEM的测量脱离不了reference和simulation以及和其他方法的比较(比如synchrotron radiation在HRXRD的使用).很多地方都在尝试中,太麻烦.
longwood
第23楼2012/04/30
Thanks, 先学习学习
tevis
第24楼2012/05/03
I don't know much about STEM. Can you explain how you deal with these factors (and Cs, thickness) in this simple equation I(x)=(h+0.5k)+0.5k*erf(k1(x-l)) ?
The images don't have scale bar. Although you use 'HRSTEM', your pictures don't seem to be high-resolution (atomic resolution). Your film thickness is not uniform (I could be wrong), so I doubt it gives you much information to get to 0.02 nm resolutionn.
While chemical compsotion certainly fluctuates throughout the sample, I haven't heard that the Fick's law (both the first law and second law) includes any error function. Could you post a reference if it does?
tevis
第26楼2012/05/04
I didn't know the error function of Fick's law until just now. Can you post a (good) paper instead of wiki? Wiki is helpful but usually cannot be used as a reference. I am wondering how this erfc function is proven to be right (and useful) for diffusion in solid materials. I briefly googled the erfc function: it is a integral from x to infinite. How do you tweak this function (also your I(x)) for your modulated thin film with limited size?
Back to your original question, my understanding is that you try to define the edges with a resolution better than 0.02 nm. It is smaller than the atomic spacing. Your images don't have this resolution.
perpetualcat68
第27楼2012/05/04
The pixel size of the HRSTEM image is 0.0223 x 0.0223nm.
Do you understand edge detection with sub-pixel accuracy based on approximation of edge
with erf function?
By the way, error function is not only an integral from x to infinite.
tevis
第30楼2012/05/04
Your explanation is very insighful to me, thanks!
Why image intensity is the convolution of beam intensity and top-hat function, not multiplication?
From your expalantion of diffusion, my understanding is that the concentration profile can be described by the error function, rather than adding an error term to the Fick's law. Is that correct?
