damoguyan
第13楼2012/07/05
2. Finished products may contain only the following production aids, used in manufacturing
and processing the raw polymer, in the maximum amounts given:
a) Condensation agents:
Residues of hydrochloric acid and its conversion products with fillers and hardeners, in
total max. 0.1 %
b) Hardeners:
α) Zinc-di-2-ethylhexoate in total
Di-n-octyl-tin-maleinate max. 1.5 %
Di-n-octyl-tin-maleinate貌似像二辛基锡啥的,但后面的单词不知道啥意思
另外BFR XV关于硅橡胶要限制的物质很多啊,怎么也有几十种吧,怎么一般测试FCM没测试几种啊?
