symmacros
第11楼2012/08/09
Sample Analysis at Mars (SAM) is an instrument on the Mars Science Laboratory ''Curiosity'' rover. The SAM instrument suite will analyze organics and gases from both atmospheric and solid samples.[1][2]
It was developed by the NASA Goddard Space Flight Center, the Laboratoire Inter-Universitaire des Systèmes Atmosphériques (LISA) (jointly operated by France's CNRS and Parisian universities) and Honeybee Robotics, along with many additional external partners.[1][3][4] The SAM suite consists of three instruments:
1.The Quadrupole Mass Spectrometer (QMS) detects gases sampled from the atmosphere or those released from solid samples by heating.[1][5]
2.The Gas Chromatograph (GC) is used to separate out individual gases from a complex mixture into molecular components. The resulting gas flow will be analyzed in the mass spectrometer with a mass range of 2-535 Daltons.[1][5]
3.The Tunable Laser Spectrometer (TLS) performs precision measurements of oxygen and carbon isotope ratios in carbon dioxide (CO2) and methane (CH4) in the atmosphere of Mars in order to distinguish between their geochemical or biological origin.[1][4][6][7][5]
The SAM also has three subsystems: the 'Chemical separation and processing laboratory', for enrichment and derivatization of the organic molecules of the sample; the sample manipulation system (SMS) for transporting powder delivered from the MSL drill to a SAM inlet and into one of 74 sample cups.[1] The SMS then moves the sample to the SAM oven to release gases by heating to up to 1000oC;[1][8] and the pumps subsystem to purge the separators and analysers.
