新加坡现代材料
第19楼2012/12/06
Iron Ore Glass Disk Preparation
Iron Ore : majority of compounds are completely oxidized; presence of different oxidation states of iron (FeO, Fe2O3 and others); LOI can be positive or negative; disk can stick to the molds if there is not enough NWA or if there is a lot of sub-oxidized Fe (FeO) in the disk; acidic.
新加坡现代材料
第20楼2012/12/06
llyang@amcabj.com Dr Claisse 铁矿石熔融制样recipe,欢迎发邮件咨询。
