symmacros
第23楼2013/01/12
Name: Oxirane, [[(2-ethylhexyl)oxy]methyl]-
Formula: C11H22O2
MW: 186 CAS#: 2461-15-6 NIST#: 291546 ID#: 21278 DB: mainlib
Other DBs: Fine, TSCA, RTECS, NIH, EINECS
Contributor: NIST Mass Spectrometry Data Center, 1998.
10 largest peaks:
57 999 | 41 370 | 55 312 | 43 303 | 56 303 |
29 278 | 70 272 | 69 253 | 83 168 | 31 163 |
Synonyms:
1.[(2-Ethylhexyl)methyl]oxirane
2.Propane, 1,2-epoxy-3-[(2-ethylhexyl)oxy]-
3.2-Ethylhexyl glycidyl ether
4.Glycidyl 2-ethylhexyl ether
5.(((2-Ethylhexyl)oxy)methyl)oxirane
6.2-Ethylhexyl 2-oxiranylmethyl ether #
wanttofly
第26楼2013/01/12
谢谢呢,估计匹配率最高的不是,有可能是下面的或其它的不在谱库里,因为不太会产生这么长烷基链的物质的,我看着质谱用反应推推看
