qq250083771
第21楼2012/12/17
216.1HPLC-ELSD法同时测定盾叶薯蓣根中3种皂苷的含量
作 者:王银红[1] 康阿龙[2] 樊宝娟[3] 孙文基[1]
WANG Yin - hong, KANG A - long, FAN Bao - juan, SUN Wen - ji(1.Biomedicine Key Laboratory of Shaanxi Province, Northwest University, Xi'an 710069, China 2. 451 Military Hospital of China, Xi'an 710055, China; 3. Shaanxi Institute for Food and Drug Control, Xi'an 710061, China)
机构地区:[1]西北大学陕西省生物医药重点实验室,西安710069 [2]解放军第四五一医院,西安710055 [3]陕西省食品药品检验所,西安710061
出 处:《药物分析杂志》 CAS CSCD 2009年第5期 739-742页,共4页
Chinese Journal of Pharmaceutical Analysis
摘 要:目的:建立同时测定盾叶薯蓣根中黄姜素A、盾叶新苷及薯蓣皂苷3种成分含量的HPLC-ELSD分析方法,考察不同产地盾叶薯蓣根中3种成分的含量。方法:药材粉末经70%乙醇回流提取,以HPLC-ELSD法进行测定。色谱柱采用Diamosil C18(250mm×4.6mm,5μm),流动相为甲醇(A)-水(B),梯度洗脱(0~10min,78%A;10~13min,78%A→90%A;13~45min,90%A),流速为1.0mL·min^-1,漂移管温度为79.0℃,气体流速为2.1L·min^-1。结果:黄姜素A、盾叶新苷和薯蓣皂苷三者均有良好的线性关系;其平均回收率(n=6)分别为100.4%,103.0%,95.3%。结论:本方法操作简便,结果可靠,可用于同时定量分析盾叶薯蓣根中黄姜素A、盾叶新苷及薯蓣皂苷3种成分。
Objective:To establish a quantitative method for the simultaneous determination of Huangjiangsu A, zingiberensis newsaponin and dioscin, and contrast the contents of three compounds in root of Dioscorea zingiberensis C. H. Wright from different habitats. Method:After refluxed with 70% ethanol, samples were separated by Diamonsil C18 column(250 mm×4.6 ram, 5 μm);The mobile phase consisted of methanol(A) -water(B) with gradient elution(0- 10 rain, 78% A;10- 13 min, 78% A→90% A;13 -45 min, 90% A),and the flow rate was 1.0 mL·min^-1. The temperature of drift tube and gas flow rate were 79.0℃ and 2.1 L·min^-1, respectively. Results:Huangjiangsu A, zingiberensis newsaponin and dioscin showed good linearity, and the average recoveries were 100. 4% , 103.0% and 95.3% , respectively. Conclusion: The method is simple and accurate for the simultaneous analysis of Huangjiangsu A, zingiberensis newsaponin and dioscin in root of Dioscorea zingiberensis.
关 键 词:盾叶薯蓣根 黄姜素A 盾叶新苷 薯蓣皂苷 HPLC-ELSD
root of Dioscorea zingiberensis C. H. Wright Huangjiangsu A zingiberensis newsaponin diosein HPLC - ELSD
分 类 号: R917 [医药、卫生 > 药学 > 药物基础科学
qq250083771
第22楼2012/12/17
216.2HPLC-ELSD同时测定灯银脑通胶囊中白果内酯、银杏内酯A、三七皂苷R_1、人参皂苷Rg_1的含量
【作者】宋金玉 康博欣 朱鸿敏 赵怀清
【摘要】:目的:建立同时测定灯银脑通胶囊中白果内酯、银杏内酯A、三七皂苷R1、人参皂苷Rg1含量的高效液相色谱-蒸发光散射检测法。方法:采用Diamonsil C18(200mm×4.6mm,5μm)色谱柱,流动相为甲醇-水-四氢呋喃(25∶70∶12),流速为1.0mL·min-1,柱温25℃,漂移管温度为110℃,载气流速为2.8L·min-1。结果:样品中白果内酯、银杏内酯A、三七皂苷R1、人参皂苷Rg1分离良好,线性范围分别为0.02~0.2mg·mL-1(r=0.9999),0.126~1.26mg·mL-1(r=0.9999),0.108~1.08mg·mL-1(r=0.9995),0.306~3.06mg·mL-1(r=0.9997);方法平均回收率(n=9)分别为100.0%,99.9%,99.8%,100.1%。结论:本法准确,专属性强,重现性好,可用于灯银脑通胶囊的质量控制。
【作者单位】: 沈阳药科大学药学院;山西生物应用职业技术学院中药系;
【关键词】: HPLC-ELSD 灯银脑通胶囊 白果内酯 银杏内酯A 三七皂苷R 人参皂苷Rg 四氢呋喃 同时测定 流动相 载气流速
qq250083771
第23楼2012/12/17
216.3HPLC-MS/MS法测定人血浆中灯盏乙素的浓度
【作者】董福明 薛烨 谢小青 张煊 刘婷立
【摘要】:目的:建立测定人血浆中灯盏乙素浓度的HPLC-MS/MS法。方法:采用Platisil ODS色谱柱(250 mm×4.6 mm,5μm),流动相为0.3%甲酸水溶液-甲醇(40∶60),流速为1.0 mL.min-1,以黄芩苷为内标,经乙酸乙酯萃取后,采用电喷雾电离化(ESI)方式和多反应离子监测(MRM)模式进行负离子检测,用于定量分析离子反应分别为m/z 461.1→285.1(灯盏乙素)和m/z 445.1→269.1(黄芩苷)。结果:线性检测范围为0.20~50.00μg.L-1,最低定量浓度0.20μg.L-1,r=0.999 3。低、中、高3个浓度的提取回收率分别为63.5%,69.5%,66.8%,基质效应分别为105.7%,97.5%,96.5%。结论:本法样品处理简单、快速,专属性强,灵敏度高,可用于灯盏乙素在人体内的药代动力学研究。
【作者单位】: 鞍山市中心医院;沈阳亿灵医药科技有限公司;
【关键词】: 灯盏乙素 血药浓度 HPLC-MS/MS
qq250083771
第24楼2012/12/17
216.4HPLC-MS/MS法测定血浆及尿中抗肿瘤药物增敏剂W198浓度
【作者】秦永平 余勤 梁茂植 邹远高 何刚
【摘要】:正W198是一种双苄异喹啉类生物碱(见图1),其活性大大高于粉防己碱而毒性较小。动物实验表明,本品与抗肿瘤药物合用,可增强耐药肿瘤细胞对抗肿瘤药物的敏感性,从而提高抗肿瘤药物的治疗效果,降低抗肿瘤药物的临床使用剂量,属一类新药,已经进行了动物药代动力学和Ⅰ期人体耐受性实验研究。为考察W198在人体内的药代动力学参数,本文建立了灵敏、准确、选择性高的HPLC-MS/MS法测定血浆及尿液中W198浓度方法。
【作者单位】:四川大学华西临床医学院临床药理研究室 四川大学华西临床医学院临床药理研究室 四川大学华西临床医学院临床药理研究室 四川大学华西临床医学院临床药理研究室 四川大学华西临床医学院临床药理研究室
qq250083771
第25楼2012/12/17
216.5HPLC-MS/MS联用技术定量测定人血浆中伊伐布雷定及其代谢产物
作 者:贾艳艳 鹿成涛 宋颖 丁莉坤 杨静 陈敏纯 李雪晴 宋薇 周伦 冯智军 文爱东
JIA Yan-yan, LU Cheng-tao, SONG Ying, DING Li-kun, YANG Jing, CHEN Min-chun, LI Xue-qin,SONG Wei,ZHOU Lun,FENG Zhi-jun,WEN Ai-dong (Department of Pharmacy, the First Affiliated Hospital of Fourth Military Medical University of PLA , Xi' an 710032, China )
机构地区:中国人民解放军第四军医大学第一附属医院药剂科,陕西西安710032
出 处:《质谱学报》 CAS CSCD 2012年第33卷第2期 81-86页,共6页
Journal of Chinese Mass Spectrometry Society
摘 要:为了定量测定人血浆中伊伐布雷定和去甲伊伐布雷定浓度,建立了HPLC-MS/MS联用方法以地西泮为内标,V(甲醇):V水(5mM醋酸铵+1%甲酸)=80:20的混合溶液为流动相,Diamosil C18(150mm×4.6mm,5μm)色谱柱为分析柱,通过电喷雾离子源(ESI),以正离子多反应监测(MRM)方式检测。用于定量分析的离子对分别为m/2469.2→177.1(伊伐布雷定),m/z455.2→177.1(去甲伊伐布雷定),m/z285.1→193.1(地西泮)。伊伐布雷定的标准曲线线性范围为0.1013~101.3μg/L,定量下限为0.1013μg/L;去甲伊伐布雷定的标准曲线线性范围为0.085~25.5μg/L,定量下限为0.085μg/L。日内、日间精密度的RSD〈15%,平均回收率〉75%。
Ivabradine and N-desmethylivabradine in human plasma was determined by high performance liquid chromatography coupled with tandem mass spectrometry (HPLC-MS/ MS). Diazepam was used as internal standard. Ivabradine and N-desmethylivabradine was separated on a Diamosil C18 column (150 mm × 4. 6 mm × 5 μm). Electrospray ionization (ESI) source was applied,and multiple reaction monitoring(MRM) mode was operated in the positive mode with the monitor ions at m/z 469.2→177.1 for ivabradine, m/z 455.2→177.1 for N-desmethylivabradine and m/z 285.1→193.1 for the internal standard, respectively. The linear calibration curve are obtained over the concentration range of 0. 101 3-quantitation are 0. 101 3 μg/L and 0. 085 μg/L for ivabradine and N-desmethylivabradine, respectively. The inter-day and intra-day precision (RSD) is less than 15%. The average recoveries are above 75%.
关 键 词:伊伐布雷定 去甲伊伐布雷定 高效液相色谱-串联质谱 血浆药物浓度
ivabradine N-desmethylivabradine high performance liquid chromatography coupled with tandem mass spectrometry (HPLC-MS/MS) plasma concentration
qq250083771
第26楼2012/12/17
216.6HPLC-MS测定人血浆中替米沙坦
作 者:樊志君
机构地区:长沙市中医院,湖南长沙410002
出 处:《中医药导报》 2007年第13卷第6期 108-110页,共3页
GUIDING JOURNAL OF TCM
摘 要:目的:建立一种测定人血浆中替米沙坦的HPLC-MS方法。方法:采用岛津C18(4.6mm×150mm,5μm)分析柱,以乙腈-水(含0.4%冰醋酸)(37:63)为流动相,流速0.95ml/min,进入质谱仪流速为0.25ml/min。内标为艾司唑仑。结果:本方法的线性范围为3.0~1800μg.L-1,最低定量限为0.5μg.L-1;方法回收率为91.95~102.87%,日内RSD均〈5%,日间RSD均〈10%。结论:本法操作简单,选择性好,灵敏度高,适用于替米沙坦的人体药代动力学研究。
Objective:To establish an HPLC - MS method for the determination of telmisartan in human plasma. Method:The analyte was separated on a Diamonsil C18 (4.6 mm × 150 mm,5μm) analytical column. The mobile phase consisted of acetonitrile - water (contain 0.4% glacial acetic acid) (37 : 63)and the/low rate was 0.95 ml/min, the/low rate of enter velocitron was 0.25 ml/ rain. Estazolam was used as internal standard. Result: The linear range of the plasma concentration of telmisartan was 3.0-1800μg·L^-1 and the limit of quantitative was 0.5 μg·L^-1. The relative recoveries of telmisartan were 91.95% - 102.87%. The RSD intra - day and inter - day were less than 5% and 10% respectively. Conclusion:This method is simple,selective and sensitive. It's suitable for the pharmacokinetic research of telmisartan in human plasma.
关 键 词:替米沙坦 药代动力学 HPLC-MS
qq250083771
第27楼2012/12/17
216.7HPLC-MS法测定大鼠尿中黄芪甲甙的含量及其尿药动力学研究
作者:顾泳川,王广基.
中文摘要:目的 建立测定大鼠尿中黄芪甲甙含量的新方法。方法 采用固相萃取高效液相色谱 质谱联用法对大鼠尿中黄芪甲甙的含量进行测定。色谱条件为 :DiamonsilTM C18(4.6mm× 2 5 0mm)柱 ,流动相 :乙腈 水 (40∶6 0 ,v/v) ,流速 0 .8ml/min ,电喷雾型质谱检测器。结果 黄芪甲甙在 0 .1~ 10 μg/ml线性良好 (r=0 .9991,n =5 ) ,最低检测限为 10ng/ml。高、中、低浓度的日内和日间变异系数均小于 10 % ,平均回收率 >90 %。用此法测定了大鼠静注黄芪甲甙后的尿药浓度并计算了药代动力学参数 ,消除速率常数k =0 .2 7h-1,肾排泄速率常数ke=2 .5× 10 -2 h-1。结论 该方法符合生物样品分析要求 ,为黄芪甲甙的体内含量测定提供了新的方法。
中文关键词:黄芪甲甙 固相萃取 HPLCMS 排泄动力学
qq250083771
第28楼2012/12/17
261.8HPLC-MS法测定人血浆中利巴韦林浓度及生物等效性的研究
【作者】黎巍
【摘要】: 目的 本研究建立一种灵敏度高、专属性强、操作简单易行的HPLC-MS方法,测定不同时间健康人血浆中的利巴韦林的血浆药物浓度。通过主要的药代动力学参数,研究利巴韦林在健康受试者体内的药物代谢动力学特点及生物利用度,评价利巴韦林在人体内是否生物等效,确保临床用药的安全性和有效性。 方法 本试验采用自身对照随机、双周期、两制剂、双交叉试验,选择18名健康受试者单剂量双交叉口服受试制剂利巴韦林软胶囊和参比制剂利巴韦林片600 mg,在不同的时间点抽取前臂静脉血。 采用HPLC-MS方法,检测器为TSQ Quantum Ultra三重四极杆串联质谱仪,色谱柱为Diamonsil C_(18)柱(150×4.6 mm I.D.,粒径5μm),流动相为甲醇-水-1%甲酸(20:80:0.5,v/v),拉米呋啶作为内标,测定不同的时间点人血浆中利巴韦林的药物浓度。 采用3P97软件计算受试制剂和参比制剂的主要药代动力学参数,C_(max)、T_(max)、AUC_(0-t)、AUC_(0-∞)采用方差分析和90%置信区间法进行生物等效性判断。 结果 在上述色谱质谱联用条件下,利巴韦林的线性范围为10.3-1288ng·ml~(-1)。最低定量限(LLOQ)为10.0 ng·ml~(-1)。回收率大于85%,日内和日间RSD均小于15%。 受试制剂和参比制剂的主要药代动力学参数T_(max)分别为1.35±0.38和1.33±0.50 h;C_(max)分别为674.8±227.7和693.9±223.3 ng·ml~(-1),T_(1/2ke)分别为25.6±6.0和26.57±5.32 h;AUC_(0-t)分别为8606.2±2132.0和8452.0±1978.8 ng·h·ml~(-1),AUC_(0-∞)分别为9903.3±2494.1和9632.1±2404.2 ng·h·ml~(-1)。以AUC_(0-t)计算,受试制剂利巴韦林软胶囊的相对生物利用度平均为102.2±9.5%。 采用方差分析和置信区间法进行生物等效性评价。结果表明受试制剂中,利巴韦林AUC_(0-t)的90%置信区间为参比制剂相应参数的97.8-105.9%,AUC_(0-t)的90%置信区间为参比制剂相应参数的98.1-107.8%,C_(max)的90%置信区间为参比制剂相应参数的85.8-109.8%。 结论 本方法简便、快速、准确。适于测定利巴韦林在人血浆中的药物浓度。根据以上结果,可判定两制剂生物等效。
【关键词】:利巴韦林 HPLC-MS法 生物等效性
【学位授予单位】:中国医科大学
【学位级别】:硕士
【学位授予年份】:2009
qq250083771
第29楼2012/12/17
216.9HPLC-UV测定人体血浆中辅酶Q_(10)浓度及其动态研究
【作者】王胜峰 邹永华 周彦彬 田娟 左英 冉黎灵 丁劲松
【摘要】:目的建立人血浆中辅酶Q10的HPLC-UV测定法,考察正常人内源性辅酶Q10的经时变化过程,并研究辅酶Q10胶囊连续给药后血浆中辅酶Q10变化规律。方法无辅酶Q10血浆经低温光照后获得,作为方法学建立的空白背景。血浆样品经正己烷-乙醇=9∶1提取后,由迪马Diamonsil C18柱(4.6 mm×200 mm,5μm)分离,流动相为甲醇-乙醇(10∶90),维生素K1为内标,检测波长为275 nm。18名志愿者在控制饮食2 d后,不同时间点采血并测定血浆中内源性辅酶Q10的变化规律,随后连续给予辅酶Q10胶囊同时间点采血,考察血浆中辅酶Q10浓度的升高情况。结果血浆中杂质不干扰样品峰,线性范围为0.156~10.0μg.mL-1(r=0.999 9),定量下限为0.156μg.mL-1。受试者经控制饮食2 d后血浆中内源性辅酶Q10浓度达到稳定状态,连续给予辅酶Q10胶囊后血浆中辅酶Q10的浓度增加明显。结论新建立的人血浆中辅酶Q10测定法,简单快速,准确度高,空白基质选择合理,处理恰当。连续给药的方法可用于评价辅酶Q10的生物利用度。
【作者单位】: 中南大学湘雅三医院;中南大学药学院;
【关键词】: 辅酶Q 高效液相色谱法 生物利用度
【分类号】:R969.11
qq250083771
第30楼2012/12/17
216.10HPLC-UV法同时测定不同产地黄柏中小檗碱和巴马汀的含量
【作者】马蓉蓉 唐意红 马春辉 李志雄 季宇彬
【摘要】:目的:建立不同产地黄柏中有效成分小檗碱和巴马汀的含量测定方法.方法:采用高效液相色谱法,测定了十六个产地黄柏中小檗碱和巴马汀的含量.色谱柱:Diamonsil~(TM)C_(18)(250mm×4.6mm,5μm):检测波长:345nm;温度:20℃;流动相:水-乙腈-冰醋酸-三乙胺(67:33:0.3:0.8.v/v);流速:1mL·min~(-1).结果:建立了同时测定黄柏中小檗碱和巴马汀的高效液相色谱法,产自广西桂林的黄柏中小檗碱含量最高,产自那坡的黄柏中巴马汀含量最高.结论:本法简便、快速、准确,适用于黄柏中小檗碱和巴马汀的含量测定.
【作者单位】: 哈尔滨商业大学生命科学与环境科学研究发展中心 中国科学院上海药物研究所 中国科学院上海药物研究所 中国科学院上海药物研究所 哈尔滨商业大学生命科学与环境科学研究发展中心
【关键词】: 黄柏 小檗碱 巴马汀 高效液相色谱法 不同产地 同时测定 对照品 三乙胺 流动相 冰醋酸
【基金】:中国科学院重要方向项目(KGCX2-SW-213-03)
