taoruo
第11楼2013/03/14
以下是checktune报告
Instrument Name | Instrument 1 | MS Model | G6430A | ||||||||||
Tune Date & Time | 2013-02-28 15:07 | ||||||||||||
Data Path | D:\MassHunter\Tune\QQQ\G6430A\Autotune_20130228_145821\atunes_20130228_150723_FAILED.TUNE.XML | ||||||||||||
Ion Source | ESI | ||||||||||||
Ionization Mode | ESI | ||||||||||||
Positive Results | |||||||||||||
Analyzer: MS1 | Polarity: Positive | Width: Unit | X | ||||||||||
m/z | m/z Exp | Tolerance | Delta | Result | FWHM | FWHM Exp | Tolerance | Delta | Result | Abundance | Minimum1 | Result | |
112.3 | 118.1 | 0.1 | -5.8 | Adjust | 11.0 | 0.7 | 0.1 | 10.3 | Adjust | 82029 | #N/A | #N/A | |
311.7 | 322.1 | 0.1 | -10.4 | Adjust | 4.6 | 0.7 | 0.1 | 3.9 | Adjust | 64130 | 0 | Pass | |
624.3 | 622.0 | 0.1 | 2.3 | Adjust | 25.0 | 0.7 | 0.1 | 24.3 | Adjust | 2863 | 0 | Pass | |
922.0 | 922.0 | 0.1 | 0.0 | Pass | 25.0 | 0.7 | 0.1 | 24.3 | Adjust | 5967 | 0 | Pass | |
1222.0 | 1222.0 | 0.1 | 0.0 | Pass | 25.0 | 0.7 | 0.1 | 24.3 | Adjust | 6025 | 0 | Pass | |
1822.0 | 1822.0 | 0.1 | 0.0 | Pass | 25.0 | 0.7 | 0.1 | 24.3 | Adjust | 6009 | 0 | Pass | |
Analyzer: MS2 | Polarity: Positive | Width: Unit | |||||||||||
118.1 | 118.1 | 0.1 | 0.0 | Pass | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 26791 | 0 | Pass | |
321.9 | 322.1 | 0.1 | -0.2 | Adjust | 0.8 | 0.7 | 0.1 | 0.1 | Pass | 14192 | 0 | Pass | |
621.9 | 622.0 | 0.1 | -0.1 | Pass | 0.8 | 0.7 | 0.1 | 0.1 | Pass | 10793 | 0 | Pass | |
921.9 | 922.0 | 0.1 | -0.1 | Pass | 0.8 | 0.7 | 0.1 | 0.1 | Pass | 9605 | 0 | Pass | |
1221.8 | 1222.0 | 0.1 | -0.2 | Adjust | 0.8 | 0.7 | 0.1 | 0.1 | Pass | 12761 | 0 | Pass | |
1821.7 | 1822.0 | 0.1 | -0.3 | Adjust | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 8561 | 0 | Pass | |
Analyzer: MS1 | Polarity: Positive | Width: Wide | |||||||||||
117.9 | 118.1 | 0.3 | -0.2 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 45543 | 0 | Pass | |
321.8 | 322.1 | 0.3 | -0.3 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 21964 | 0 | Pass | |
622.1 | 622.0 | 0.3 | 0.1 | Pass | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 51 | 0 | Pass | |
125.0 | 922.0 | 0.3 | -797.0 | Adjust | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 35 | 0 | Pass | |
125.0 | 1222.0 | 0.3 | -1097.0 | Adjust | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 35 | 0 | Pass | |
125.0 | 1822.0 | 0.3 | -1697.0 | Adjust | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 0 | 0 | Pass | |
Analyzer: MS2 | Polarity: Positive | Width: Wide | |||||||||||
118.1 | 118.1 | 0.3 | 0.0 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 35065 | 0 | Pass | |
322.0 | 322.1 | 0.3 | -0.1 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 20387 | 0 | Pass | |
621.9 | 622.0 | 0.3 | -0.1 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 15866 | 0 | Pass | |
921.9 | 922.0 | 0.3 | -0.1 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 18563 | 0 | Pass | |
1221.8 | 1222.0 | 0.3 | -0.2 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 29407 | 0 | Pass | |
1821.8 | 1822.0 | 0.3 | -0.2 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 31916 | 0 | Pass | |
Analyzer: MS1 | Polarity: Positive | Width: Widest | |||||||||||
117.8 | 118.1 | 0.5 | -0.3 | Pass | 2.6 | 2.5 | 1.3 | 0.1 | Pass | 60454 | 0 | Pass | |
321.7 | 322.1 | 0.5 | -0.4 | Pass | 2.7 | 2.5 | 1.3 | 0.2 | Pass | 34020 | 0 | Pass | |
624.9 | 622.0 | 0.5 | 2.9 | Adjust | 1.2 | 2.5 | 1.3 | -1.3 | Pass | 459 | 0 | Pass | |
125.0 | 922.0 | 0.5 | -797.0 | Adjust | 25.0 | 2.5 | 1.3 | 22.5 | Adjust | 35 | 0 | Pass | |
125.0 | 1222.0 | 0.5 | -1097.0 | Adjust | 25.0 | 2.5 | 1.3 | 22.5 | Adjust | 35 | 0 | Pass | |
1821.9 | 1822.0 | 0.5 | -0.1 | Pass | 25.0 | 2.5 | 1.3 | 22.5 | Adjust | 35 | 0 | Pass | |
Analyzer: MS2 | Polarity: Positive | Width: Widest | |||||||||||
118.0 | 118.1 | 0.5 | -0.1 | Pass | 2.6 | 2.5 | 1.3 | 0.1 | Pass | 57077 | 0 | Pass | |
322.0 | 322.1 | 0.5 | -0.1 | Pass | 2.6 | 2.5 | 1.3 | 0.1 | Pass | 36102 | 0 | Pass | |
621.9 | 622.0 | 0.5 | -0.1 | Pass | 2.8 | 2.5 | 1.3 | 0.3 | Pass | 25740 | 0 | Pass | |
922.0 | 922.0 | 0.5 | 0.0 | Pass | 2.5 | 2.5 | 1.3 | 0.0 | Pass | 31926 | 0 | Pass | |
1222.0 | 1222.0 | 0.5 | 0.0 | Pass | 2.4 | 2.5 | 1.3 | -0.1 | Pass | 52272 | 0 | Pass | |
1821.9 | 1822.0 | 0.5 | -0.1 | Pass | 2.5 | 2.5 | 1.3 | 0.0 | Pass | 61962 | 0 | Pass | |
¹ NOTE: | 1) Actual abundances depend on many factors and are instrument specific. | ||||||||||||
To change the minimum abundance, edit the values on the "Options" sheet. | |||||||||||||
Negative Results | |||||||||||||
Analyzer: MS1 | Polarity: Negative | Width: Unit | X | ||||||||||
112.9 | 113.0 | 0.1 | -0.1 | Pass | 0.8 | 0.7 | 0.1 | 0.1 | Pass | 26310 | 0 | Pass | |
301.9 | 302.0 | 0.1 | -0.1 | Pass | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 118681 | 0 | Pass | |
607.6 | 602.0 | 0.1 | 5.6 | Adjust | 10.5 | 0.7 | 0.1 | 9.8 | Adjust | 15897 | 0 | Pass | |
607.6 | 1034.0 | 0.1 | -426.4 | Adjust | 10.5 | 0.7 | 0.1 | 9.8 | Adjust | 0 | 0 | Pass | |
607.6 | 1334.0 | 0.1 | -726.4 | Adjust | 10.5 | 0.7 | 0.1 | 9.8 | Adjust | 0 | 0 | Pass | |
607.6 | 1933.9 | 0.1 | -1326.3 | Adjust | 10.5 | 0.7 | 0.1 | 9.8 | Adjust | 0 | 0 | Pass | |
Analyzer: MS2 | Polarity: Negative | Width: Unit | |||||||||||
112.9 | 113.0 | 0.1 | -0.1 | Pass | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 292437 | 0 | Pass | |
301.9 | 302.0 | 0.1 | -0.1 | Pass | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 128332 | 0 | Pass | |
601.9 | 602.0 | 0.1 | -0.1 | Pass | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 416108 | 0 | Pass | |
1033.8 | 1034.0 | 0.1 | -0.2 | Adjust | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 576498 | 0 | Pass | |
1333.8 | 1334.0 | 0.1 | -0.2 | Adjust | 0.7 | 0.7 | 0.1 | 0.0 | Pass | 962218 | 0 | Pass | |
1933.7 | 1933.9 | 0.1 | -0.2 | Adjust | 0.8 | 0.7 | 0.1 | 0.1 | Pass | 638405 | 0 | Pass | |
Analyzer: MS1 | Polarity: Negative | Width: Wide | |||||||||||
112.9 | 113.0 | 0.3 | -0.1 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 32043 | 0 | Pass | |
301.8 | 302.0 | 0.3 | -0.2 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 175388 | 0 | Pass | |
607.4 | 602.0 | 0.3 | 5.4 | Adjust | 10.7 | 1.2 | 0.6 | 9.5 | Adjust | 17282 | 0 | Pass | |
125.0 | 1034.0 | 0.3 | -909.0 | Adjust | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 36 | 0 | Pass | |
1334.0 | 1334.0 | 0.3 | 0.0 | Pass | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 39 | 0 | Pass | |
1933.9 | 1933.9 | 0.3 | 0.0 | Pass | 25.0 | 1.2 | 0.6 | 23.8 | Adjust | 40 | 0 | Pass | |
Analyzer: MS2 | Polarity: Negative | Width: Wide | |||||||||||
113.0 | 113.0 | 0.3 | 0.0 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 387095 | 0 | Pass | |
301.9 | 302.0 | 0.3 | -0.1 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 189791 | 0 | Pass | |
601.8 | 602.0 | 0.3 | -0.2 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 744957 | 0 | Pass | |
1033.8 | 1034.0 | 0.3 | -0.2 | Pass | 1.3 | 1.2 | 0.6 | 0.1 | Pass | 1392607 | 0 | Pass | |
1333.7 | 1334.0 | 0.3 | -0.3 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 2866173 | 0 | Pass | |
1933.6 | 1933.9 | 0.3 | -0.3 | Pass | 1.2 | 1.2 | 0.6 | 0.0 | Pass | 2206217 | 0 | Pass | |
Analyzer: MS1 | Polarity: Negative | Width: Widest | |||||||||||
112.8 | 113.0 | 0.5 | -0.2 | Pass | 2.7 | 2.5 | 1.3 | 0.2 | Pass | 39615 | 0 | Pass | |
301.8 | 302.0 | 0.5 | -0.2 | Pass | 2.8 | 2.5 | 1.3 | 0.3 | Pass | 257529 | 0 | Pass | |
604.8 | 602.0 | 0.5 | 2.8 | Adjust | 1.4 | 2.5 | 1.3 | -1.1 | Pass | 60341 | 0 | Pass | |
125.0 | 1034.0 | 0.5 | -909.0 | Adjust | 25.0 | 2.5 | 1.3 | 22.5 | Adjust | 36 | 0 | Pass | |
125.0 | 1334.0 | 0.5 | -1209.0 | Adjust | 25.0 | 2.5 | 1.3 | 22.5 | Adjust | 0 | 0 | Pass | |
125.0 | 1933.9 | 0.5 | -1808.9 | Adjust | 25.0 | 2.5 | 1.3 | 22.5 | Adjust | 0 | 0 | Pass | |
Analyzer: MS2 | Polarity: Negative | Width: Widest | |||||||||||
112.9 | 113.0 | 0.5 | -0.1 | Pass | 2.6 | 2.5 | 1.3 | 0.1 | Pass | 536778 | 0 | Pass | |
301.9 | 302.0 | 0.5 | -0.1 | Pass | 2.6 | 2.5 | 1.3 | 0.1 | Pass | 287462 | 0 | Pass | |
601.9 | 602.0 | 0.5 | -0.1 | Pass | 2.6 | 2.5 | 1.3 | 0.1 | Pass | 1114457 | 0 | Pass | |
1033.9 | 1034.0 | 0.5 | -0.1 | Pass | 2.5 | 2.5 | 1.3 | 0.0 | Pass | 2457502 | 0 | Pass | |
1333.8 | 1334.0 | 0.5 | -0.2 | Pass | 2.5 | 2.5 | 1.3 | 0.0 | Pass | 5538127 | 0 | Pass | |
1933.8 | 1933.9 | 0.5 | -0.1 | Pass | 2.3 | 2.5 | 1.3 | -0.2 | Pass | 5264742 | 0 | Pass | |
