You're right. Since my computer has something wrong with it, I temporarily use collegue's, but only english keybord can be used. So that is why I wrote in English. Sorry for that.
wccd(wccd)发表:Why did you want to comapre the detectors, for application ? 错了
应该是 Why did you want to compare the detectors, for application ?
bairuizheng(bairuizheng)发表:You're right. Since my computer has something wrong with it, I temporarily use collegue's, but only english keybord can be used. So that is why I wrote in English. Sorry for that.
