xiaowang268
第11楼2013/05/12
这些数据是来自?
ACD/LogP: | 10.159 | # of Rule of 5Violations: | 2 |
ACD/LogD (pH 5.5): | 8.98 | ACD/LogD (pH 7.4): | 7.19 |
ACD/BCF (pH 5.5): | 1000000.00 | ACD/BCF (pH 7.4): | 33247.36 |
ACD/KOC (pH 5.5): | 533830.80 | ACD/KOC (pH 7.4): | 8597.75 |
#H bond acceptors: | 5 | #H bond donors: | 1 |
#Freely Rotating Bonds: | 17 | Polar Surface Area: | 72.83 Å2 |
Index of Refraction: | 1.498 | Molar Refractivity: | 155.355 cm3 |
Molar Volume: | 529.618 cm3 | Polarizability: | 61.587 10-24cm3 |
Surface Tension: | 37.5320014953613 dyne/cm | Density: | 1.002 g/cm3 |
Flash Point: | 186.97 °C | Enthalpy of Vaporization: | 97.392 kJ/mol |
Boiling Point: | 625.837 °C at 760 mmHg | Vapour Pressure: | 0 mmHg at 25°C |
