雾非雾
第12楼2013/06/07
新鲜蘑菇里的风味物质可能会更多些,这样可能净化也更困难一些,我们是用乙腈萃取,这样用盐分水一步应该能去掉一些杂质,我们也是用NH2净化的,对于您说的这些杂质,如果有条件可以考虑试试用C18柱先过柱,然后分取乙腈层,浓缩除去乙腈后,再用PSA净化一下试试看效果如何,建议就直接转换成丙酮:正己烷(1:4),因为正向柱的上样液和活化溶剂可以是一样的。
化合物编号 | 保留时间 | 名称 | 峰面积 | 匹配度 |
1 | 4.146 | Benzyl alcohol | 31613787 | 97 |
2 | 4.781 | Demeton-S methyl | 22894602 | 4 |
3 | 9.992 | Diethyl phthalate | 17469581 | 98 |
4 | 11.904 | n-C17H36(Heptadecane) | 8030347 | 96 |
5 | 12.033 | n-C22H46(Docosane) | 9436901 | 50 |
6 | 14.18 | n-C18H38(Octadecane) | 10823649 | 98 |
7 | 14.415 | n-C22H46(Docosane) | 18203157 | 80 |
8 | 15.951 | Di-n-octyl phthalate | 102971177 | 50 |
9 | 18.433 | Di-n-octyl phthalate | 318893556 | 59 |
10 | 21.65 | Chloridazon | 9340494 | 37 |
11 | 26.238 | n-C23H48(Tricosane) | 7122451 | 96 |
12 | 27.738 | Adipic acid, bis-2-ethylhexylester | 31564540 | 52 |
13 | 28.026 | Tefluthrin | 37749161 | 25 |
14 | 28.956 | n-C27H56(Heptacosane) | 11715879 | 59 |
15 | 29.044 | n-C31H64(Hentriacontane) | 18491866 | 62 |
16 | 29.685 | Bis(2-ethylhexyl)phthalate | 611524115 | 91 |
17 | 30.214 | n-C31H64(Hentriacontane) | 27707757 | 53 |
18 | 30.856 | n-C27H56(Heptacosane) | 45980091 | 90 |
19 | 31.032 | n-C27H56(Heptacosane) | 16089118 | 74 |
20 | 31.308 | n-C27H56(Heptacosane) | 14596635 | 78 |
21 | 33.485 | n-C33H68(Tritriacontane) | 7786143 | 95 |
1 | 5.375 | Naphthalene-d8 | 17139456 | 95 |
2 | 8.375 | Acenaphthene-d10 | 29453399 | 64 |
3 | 13.727 | Phenanthrene-d10 | 19646956 | 93 |
4 | 15.951 | Di-n-octyl phthalate | 96792143 | 50 |
5 | 18.445 | Di-n-octyl phthalate | 229448337 | 39 |
6 | 20.715 | Fluoranthene-d10 | 23568837 | 98 |
7 | 23.068 | Indanofan | 20704913 | 60 |
8 | 27.732 | Adipic acid, bis-2-ethylhexylester | 14803433 | 62 |
9 | 28.374 | Chrysene-d12 | 27075160 | 91 |
10 | 29.032 | n-C33H68(Tritriacontane) | 9104653 | 97 |
11 | 29.673 | Bis(2-ethylhexyl)phthalate | 433791554 | 91 |
12 | 30.209 | n-C30H62(Triacontane) | 15500071 | 76 |
13 | 31.303 | n-C27H56(Heptacosane) | 7991840 | 95 |
