cjh0576
第25楼2015/06/16
Plasma went out unexpectedly.
If this happened during ignition, try the following:
? Observe the plasma discharge during ignition through the
viewing window. If the plasma lights, but then extinguishes
right away, check the argon flows, torch condition, and test
for air leaks.
? If the sample is very volatile, try a less volatile sample or
switch to water.
? If analyzing volatile samples, a higher power setting and
lower nebulizer gas flow rate may be required.
If this happened during normal operation then the plasma
detection circuit that monitors the plasma is the most likely
problem. If you continue to have problems, contact
PerkinElmer service and arrange a service visit.
[0516]
这个问题有谁遇到过?
先是测样过程中突然熄火
重新点火,基本20秒内又熄火了
ymnh
第26楼2017/08/30
