fgx123
第12楼2007/07/13
美国安捷伦公司1200液相色谱(四元泵系统)
G1354A "1200 Quaternary Pump with Degasser,
四元泵及配套真空脱气机"
G1354A-030 "Seal wash kit
密封清洗工具包"
G1314B "1200 Series Variable Wavelength Det.
可编程可变波长紫外检测器"
G1314B-018 "Standard Flow cell
标准流通池"
G2170BA "HPLC 2D ChemStation Software 32bit,
32bit HPLC 2D化学工作站"
G1328B "1200 Series Manual Injector,
手动进样器, 包括Rheodyne 7725手动进样阀,20ul样品环和安装架"
G1316A "1200 Thermostatted Column Compartment,
半导体控温柱温箱,可控温范围:室温下10℃-80℃"
5182-9719 "Syringe LC, 25ul, RN,
25ul固定针头式注射器"
993967-902 "Eclipse XDB-C18 4.6x150 5u Analytical
ZORBAX Eclipse XDB-C18 分析柱"
820888-901 "High Perf. Zorbax Guard Fittings Kit
保护柱配套组件盒"
820950-925 "XDB-C18 Grd.Crt.4.6x12.5mm,4/PK
保护柱,4/包"
0100-1516 "Fingertight fitting PEEK 1/16"" 2/pk,
1/16""PEEK, 手拧PEEK接头(2/PK)"
0890-1763 "1/16""od 0.007""id (0.18mm) 1.5m PEEK tbng,
0.18mm x 1.5m PEEK 管"
01018-22707 "PTFE Frits 5PK,
PTFE过滤芯,5/包"
以上配制打折下来250000元
