第19楼2004/05/19
其实我觉得大家争论的焦点是在EPA3545方法,chief说只有dione和supelco符合标准,jzy0719说别的也可以,哪位英文好的帮忙把下面的给翻译一下:
4.1 Pressurized fluid extraction device
4.1.1 Dionex Accelerated Solvent Extractor or Supelco SFE-400 with appropriatelysized
extraction cells. Currently, cells are available that will accommodate 10-g, 20-g and 30-
g samples. Cells should be made of stainless steel or other material capable of withstanding
the pressure requirements (2000+ psi) necessary for this procedure.
4.1.2 Other system designs may be employed, provided that adequate
performance can be demonstrated for the analytes and matrices of interest.
