70码
第35楼2014/11/11
DC Rod test: (5 May 2014 11:26:10)
Quad 1 RF/DC Correction OK
Plus Quad 0 driver set to -30 V read -13 V Failed! --> Test Failed!
Plus Quad 0 driver set to -60 V read -12 V Failed! --> Test Failed!
Plus Quad 0 driver set to -90 V read -13 V Failed! --> Test Failed!
Plus Quad 0 driver set to -120 V read -12 V Failed! --> Test Failed!
Plus Quad 0 driver set to -150 V read -13 V Failed! --> Test Failed!
Quad 1 DC- OK
Quad 1 DC+ OK
Quad 3 RF/DC Correction OK
Plus Quad 2 driver set to -30 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -60 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -90 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -120 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -150 V read -12 V Failed! --> Test Failed!
Quad 3 DC- OK
Quad 3 DC+ OK
DC Rod test: <<< FAILED >>>
xww428
第38楼2018/03/12
300msms也出现此状况了,悲摧了
Lens 4 set to 0 V and reads back 130 V --> Test Failed
Lens 4 set to 30 V and reads back 132 V --> Test Failed
Lens 4 set to 60 V and reads back 133 V --> Test Failed
Lens 4 set to 90 V and reads back 135 V --> Test Failed
Lens 4 set to 120 V and reads back 141 V --> Test Failed
Lens 4 set to 150 V and reads back 154 V --> Passed
Lens 4 set to -30 V and reads back 130 V --> Test Failed
Lens 4 set to -60 V and reads back 129 V --> Test Failed
Lens 4 set to -90 V and reads back 128 V --> Test Failed
Lens 4 set to -120 V and reads back 128 V --> Test Failed
Lens 4 set to -150 V and reads back 127 V --> Test Failed
Lens 4 Failed
