xiaolaohu
第14楼2006/09/15
是的 没有洗干净的话 三次replicates的Hg的特征峰值会依次降低.也就是说一定要洗到空白值测不出为止么? 那得需要洗很长时间耶
数据见下
Hg 184.887 Hg 194.164 Hg 253.652
Blank 0 0 0
Standard1 10 10 10
Standard2 20 20 20
空白 (H2O洗约1min) 0.173583 0.163304 0.152728
空白 (20% HNO3洗约1min) 0.122669 0.117909 0.112459
空白 (1ppm Au溶液洗约1min) 0.056696 0.047244 0.045234
空白 (1ppm Au溶液洗约1min) 0.033386 0.032349 0.029632
6 0.087585 0.086116 0.094487
空白 (1ppm Au溶液洗约1min) 0.014478 0.01079 0.009893
5 0.038419 0.036992 0.046988
空白 (1ppm Au溶液洗约1min) 0.011021 0.005632 0.005434
4 0.018658 0.019142 0.024801
空白 (20% HNO3 溶液洗约1min) 0.010885 0.006135 0.004445
空白 (1ppm Au溶液洗约1min) 0.002464 0.002105 0.000504
3 0.008542 0.009515 0.014129
空白 (1ppm Au溶液洗约2min) 0.002863 0.000319 -0.000407
2 0.010841 0.0009108 0.011902
空白 (1ppm Au溶液洗约2min) 0.002627 -0.000957 -0.001369
1 0.005664 0.004176 0.006372
6 0.018336 0.018177 0.023895
空白 0.001671 -0.000333 -0.002385
5 0.014552 0.012674 0.020891
空白 0.00167 -0.001278 -0.002397
6 0.014243 0.014928 0.021754
空白 -0.000581 -0.001255 -0.002347
5 0.00974 0.008235 0.017721
空白 0.000904 -0.001685 -0.00351
0 7.08979 6.78512 6.48676
空白 (1ppm Au溶液洗约3min) 0.025266 0.020111 0.020169
空白 (1ppm Au溶液洗约5min) 0.01784 0.014552 0.01172
Std2 8.64589 8.33381 8.28876
0# 8.14454 7.79052 7.53843
空白 0.068745 0.06358 0.0588
5# 0.136319 0.130455 0.136101
4# 0.077461 0.071316 0.069044
2# 0.826414 0.792006 0.763287
3# 0.169529 0.162271 0.154121
1# 1.33514 1.28751 1.22208
空白 0.05831 0.052983 0.04877
2# 0.939798 0.903955 0.866614
Std2 8.54759 8.23828 8.14769
备注:0,0#样品理论值为10ppm.
