点击领取任务出来的就是:
ERROR
The requested URL could not be retrieved
While trying to process the request: GET /vip/task/ HTTP/1.1Accept: */*Referer: http://bbs.instrument.com.cn/shtml/20141223/5585586/index_1.shtmlAccept-Language: zh-CNUser-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729)Host:
www.instrument.com.cnConnection: Keep-AliveCookie: Hm_lvt_0734da4eac2008c2d1116b5f7bf16165=1419859651,1419864340,1419868447,1419904834; __utma=171805176.1414946472.1419858708.1419920172.1419929504.5; __utmz=171805176.1419905531.2.2.utmcsr=bbs.instrument.com.cn|utmccn=(referral)|utmcmd=referral|utmcct=/; nickname=wsy18; useid=1636655; username=wsy18; CheckValid=cdb8c459a06574e5ce16ac466b8542b1; username_guestbook=1636655; dsp={"1,27,":"1419908092_4","8,26,":"1419905171_4","8,":"1419907999_4","27,":"1419908874_4"}; __utmb=171805176.1.10.1419929504; __utmt=1; Hm_lpvt_0734da4eac2008c2d1116b5f7bf16165=1419929709; 3i=2014122921101211; __utmc=171805176; getdddd=NA4P; ASP.NET_SessionId=hmdmzleqcrt1isia5ynimr2g; ASPSESSIONIDAAQCSSAD=DBOPFKDAMBIICDOHKKDELCEO; ASPSESSIONIDSCRDQSAD=DBENBDGACCHBICHDNJHEFHJD; ASPSESSIONIDCASDSSBC=KJNJNLIAKDDBGONPOAIGKEKO; ASPSESSIONIDAAQCTSAC=IFDLCHJAGPEDJFFGKMGJGMCI; ASPSESSIONIDQAQBQQDD=IJJMJELAPGILJLOBLNLLPPKF; ASPSESSIONIDSQBDRRDA=EHDIBNPAMOKDPFCMCFMJKJHH; ASPSESSIONIDAAQCQSDA=OPNHGNNABHKAEBAKIBAIHKBD; ASPSESSIONIDSSBDQRAC=MMDDCGABMBFLGOJJBLAONKCKCdn-Src-Ip: 118.132.59.247X-Forwarded-For: 118.132.59.247Accept-Encoding: gzip
The following error was encountered:
The HTTP Response message received from the contacted server could not be understood or was otherwise malformed. Please contact the site operator. Your cache administrator may be able to provide you with more details about the exact nature of the problem if needed.
ÍøÂçÕï¶Ï
Çëµã»÷:
ÍøÂçÕï¶ÏÁªÏµ±¾»º´æ·þÎñÆ÷¹ÜÀíÔ±
Çëµã»÷: bts_qs@chinanetcenter.com
